1 members (Gone),
180
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,183 Posts1,057,263 Members48,467 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2018 Posts: 35 Wrench Fetcher | | Wrench Fetcher Joined: May 2018 Posts: 35 | Hey guys how's it going, I'm currently rebuilding my 1954 3100. Part of the process is an all new fuel system. I have new fuel tank, sending unit, fuel pump, rebuilt carb, and Main fuel line and pump to carb line. I even got a replacement for the little rubber hose that connects the main fuel line to the sending unit drop line. The only thing I can't find a replacement for is the drop line that goes from the fuel sending unit, down to the little rubber hose under the cab! Any idea where I can find one or will I be stuck trying to bend a new one? Thanks! | | | | | Joined: Mar 2010 Posts: 10,309 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,309 | I made one out of the nickle/copper fuel line from Advance Auto Parts. It may have been a brake line, but as long as the fitting is correct it doesn't matter. That nickle/copper line is a dream to bend.
| | | | | Joined: May 2019 Posts: 2 New Guy | | New Guy Joined: May 2019 Posts: 2 | Hi ...... looking for replacement fuel / vacuum lines for my 1954 Chevy 5700. Any suggestions who sell pre bent lines. Thanks
| | | | | Joined: Jan 2002 Posts: 2,845 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,845 | Danny, Get a roll of nickle / copper fuel line and bend it yourself. So easy.
Craig My '50 Chevy 3100 5 window, '62-235cu, 3:55 rear My truck ....... Respect The Rust If I'm not working on my truck, '65 m00stang or VW camper, I'm fishing with the wife or smoking Salmon.
| | | | | Joined: Feb 2016 Posts: 1,996 'Bolter | | 'Bolter Joined: Feb 2016 Posts: 1,996 | DannyZ, I have a '57 5700 LCF. I bought a 25ft. coil of 1/4in cupro-nickel line from Summit Racing, had enough to replace every bit of the old lines.
