5 members (tclederman, gswbbc, Uncles51, dwreills, Peggy M), 83 guests, and 2 robots.
Topics128,035
Posts1,055,446
Members48,422
#1266274 05/17/2018 10:58 PM
The horn quit on my 56 and in looking at replacements, I see that there are two horns available, one high and one low. When I got this truck, there was only one horn on the left side, of fairly new vintage, and nothing on the right, not even an empty mounting bracket. My questions are; was only one horn an option on this truck when new, and if so, should I get the high or the low? The one that broke was a Wolo 385-2T, high. I would not mind going with two except I would need to find another bracket for mounting.
Thanks, Lee.
1956 Chevy 3200, 235 w/3 speed
LeeD #1266285 05/18/2018 1:20 AM
Sir Searchalot
Sir Searchalot
Looks like one horn "low note" left side.
Two horns for Cameo.
Right horn, "high note", available from Parts and Accessories Dept. and installed by dealer or customer.
LeeD #1266296 05/18/2018 3:01 AM
Thank you Bartamos, that explains how it came off the line and tells me to find a low note horn.
LeeD #1266303 05/18/2018 6:35 AM
I've tried both and can confirm that you definitely want the LOW tone.
1951 Chevy Panel Truck
LeeD #1266443 05/20/2018 2:04 AM
Classic Industries has a low tone by AC Delco that I have ordered. A little pricey, but the Wolo that was in there only lasted about a year and a half. I called around to several of the local flaps (including an AC Delco distributor) and all anybody had or could order was the cheap universal variety.
Thanks to all for your help.
Lee.
LeeD #1266455 05/20/2018 4:14 AM
Sir Searchalot
Sir Searchalot
Thanks for the follow up Lee.
LeeD #1266457 05/20/2018 5:06 AM
The bracket for the horns is riveted to the horn from the factory, when you find the correct horn, you'll have the bracket. They bolt to the core support with one bolt going down into the top and one bolt going into the vertical part of the core support top angle iron on the engine side...there are louvers cut into the core support side panels to let the sound out.
The correct horns are the "sea shell" type with half of a sphere cover.
Left Low stamped 759
Right Hi stamped 760
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
LeeD #1266514 05/20/2018 11:57 PM
Thanks for the info Mike. My left side horn was just bolted through a hole in the bracket, if it were originally riveted, then it must have been drilled out at some time in the past. I noticed that I have the same bolt pattern ( and bolts!) on the right side, so it would be easy to add the second horn.
Lee.
LeeD #1266612 05/22/2018 5:17 AM
There is a left and right horn and horn bracket...they are a mirror image of each other.
Mike B smile
Mike Boteler
1984 Jeep CJ7
Silver Spring, MD
LeeD #1266813 05/24/2018 1:22 AM
Thanks Mike, I had not realized that.
