8 members (msmall, 68ironhead, Shardean, DannyW, Eisenholtz, 3800GUY, Shade Baby, cmayna),
41
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,023 Posts1,055,367 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2017 Posts: 326 'Bolter | | 'Bolter Joined: Mar 2017 Posts: 326 | The horn quit on my 56 and in looking at replacements, I see that there are two horns available, one high and one low. When I got this truck, there was only one horn on the left side, of fairly new vintage, and nothing on the right, not even an empty mounting bracket. My questions are; was only one horn an option on this truck when new, and if so, should I get the high or the low? The one that broke was a Wolo 385-2T, high. I would not mind going with two except I would need to find another bracket for mounting.
Thanks, Lee.
1956 Chevy 3200, 235 w/3 speed
| | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | Looks like one horn "low note" left side.
Two horns for Cameo.
Right horn, "high note", available from Parts and Accessories Dept. and installed by dealer or customer.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Mar 2017 Posts: 326 'Bolter | | 'Bolter Joined: Mar 2017 Posts: 326 | Thank you Bartamos, that explains how it came off the line and tells me to find a low note horn.
| | | | | Joined: Dec 2014 Posts: 678 'Bolter | | 'Bolter Joined: Dec 2014 Posts: 678 | I've tried both and can confirm that you definitely want the LOW tone.
1951 Chevy Panel Truck
| | | | | Joined: Mar 2017 Posts: 326 'Bolter | | 'Bolter Joined: Mar 2017 Posts: 326 | Classic Industries has a low tone by AC Delco that I have ordered. A little pricey, but the Wolo that was in there only lasted about a year and a half. I called around to several of the local flaps (including an AC Delco distributor) and all anybody had or could order was the cheap universal variety.
Thanks to all for your help.
Lee.
| | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | Thanks for the follow up Lee.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Mar 2004 Posts: 6,212 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,212 | The bracket for the horns is riveted to the horn from the factory, when you find the correct horn, you'll have the bracket. They bolt to the core support with one bolt going down into the top and one bolt going into the vertical part of the core support top angle iron on the engine side...there are louvers cut into the core support side panels to let the sound out. The correct horns are the "sea shell" type with half of a sphere cover. Left Low stamped 759 Right Hi stamped 760 Mike B  | | | | | Joined: Mar 2017 Posts: 326 'Bolter | | 'Bolter Joined: Mar 2017 Posts: 326 | Thanks for the info Mike. My left side horn was just bolted through a hole in the bracket, if it were originally riveted, then it must have been drilled out at some time in the past. I noticed that I have the same bolt pattern ( and bolts!) on the right side, so it would be easy to add the second horn.
Lee.
| | | | | Joined: Mar 2004 Posts: 6,212 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,212 | There is a left and right horn and horn bracket...they are a mirror image of each other. Mike B  | | | | | Joined: Mar 2017 Posts: 326 'Bolter | | 'Bolter Joined: Mar 2017 Posts: 326 | Thanks Mike, I had not realized that.
