2 members (55shaker, 1 invisible),
55
Mod | | | Forums66 Topics128,076 Posts1,055,920 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2017 Posts: 82 Shop Shark | | Shop Shark Joined: Nov 2017 Posts: 82 | Hey guys I am looking for some one who could set up a ring and pinion in my 52 chevy panel half ton . I live in Epping ,New Hampshire. I have called 5 different local shops and none of them do that kind of work. It currently has 4.11 rear gears an only does 35 MPH ... I would like to get 3.55 set up in to it.
| | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Faster gears will help.
Also adjust and tune your engine, 35 mph is very slow even for the stock setup. Adjust the valves. Set timing, for a likely good setting try 10 degrees advanced at an idle with vacuum advance disconnected. (Reconnect before driving)
You should easily and comfortably achieve 55 mph stock. | | | | | Joined: Dec 2014 Posts: 357 'Bolter | | 'Bolter Joined: Dec 2014 Posts: 357 | I believe your 4.11 gears should be fine. Something else is not right. Do as Grigg said. Find out why your truck is slow.
What's the highest RPM that the motor turns.
Julian Carter
1970 Triumph GT6 1967 Triumph TR4A 1952 Chevy 3600 1948 MG-TC
| | | | | Joined: Nov 2017 Posts: 82 Shop Shark | | Shop Shark Joined: Nov 2017 Posts: 82 | thanks guys ..I forgot to tell you I have a 1958 235 engine in my 52 panel.. it has a 3 speed on the column transmission that I assume is stock. when I try to go faster than 35 it sounds like it is revving very high and I don't want to damage the engine as I have been told that the old inline engines can't take high rpms. also where might on find a manual to tell me how to tune my engine like you fellas suggested?
| | | | | Joined: Apr 2005 Posts: 7,440 Bolter | | Bolter Joined: Apr 2005 Posts: 7,440 | The OP is now posting his question in the "Engine Forum".
| | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | Do you have 15" wheels on your panel? | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | | | | | | Joined: Jan 2013 Posts: 1,518 'Bolter | | 'Bolter Joined: Jan 2013 Posts: 1,518 | I have seen this before and it was a slipping clutch, or clutch disc installed backwards
1953 Chevrolet 3100261 cu inch, sm420, 3.55 rear, torque tube still,omaha orange, still 6 volt, RPO green glass, side carrier spare, all done In the DITY GalleryVideo of the 261 running1964 GMC 1000305 Big Block V6, sm420, the next cab off restoration
| | | | | Joined: Mar 2010 Posts: 843 Shop Shark | | Shop Shark Joined: Mar 2010 Posts: 843 | Good morning Wendell.
If you are still considering switching from 4.11 to 3.55 I'd like to pass along a couple of things.
First, I did that exact gear change in my restored '36 Chevy pickup and it was a huge improvement. I can enthusiastically recommend it. Even the stock 207 engine pulls the 3.55 gears easily, even on hills.
Second, installing a ring gear and pinion is very doable by an amateur. I did my own and I'm a geologist, not a mechanic. There are videos on exactly how to do it. The only special tool required is a dial indicator to check the "backlash" (Clearance) between the ring gear and pinion. A buddy's wife is an artist and she gave me a dab of titanium white paint to put on the gear teeth to be able to see the contact pattern.
You can do it!
Ray
| | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | I have seen this before and it was a slipping clutch, or clutch disc installed backwards This was my immediate thought on this also. It's almost the only way a truck can suddenly rev high and not go very fast. Pull up to a telephone pole and put your bumper against it with a blanket in between. Be sure to be at a bumper brace. Put it in second and slowly let clutch out. NO GAS. Should buck a little and motor should die right away. If you don't want to do that just think about it, does the motor and speed match when starting out in first? You should be able to sense that motor reaches high RPM way faster than truck is moving from dead stop. That is a worn out clutch.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Nov 2017 Posts: 82 Shop Shark | | Shop Shark Joined: Nov 2017 Posts: 82 | very interesting.. I was wondering about the clutch... ( sstock)
yar , thank you for your encouragement . my other issue is I do not have a place to work on it to that extent. | | |
