2 members (dt235sd, Southerntruck), 145 guests, and 8 robots.
Topics128,077
Posts1,056,033
Members48,433
#1266180 05/17/2018 1:34 AM
Today while cleaning out the external oil filter canister on my 54 235, I could not see how the oil returns to the block. The drain tube screws into a pipe that goes to the top where the cap screw is. The only way that I can see for the oil to get out of the canister is through a little hole near the top of the tube. Is that it or am I missing something?
Leo Offline
Moderator
Moderator
You would be surprised how much oil can go through that little hole.
There is a hole about 1/16" in diameter about halfway up the center standpipe or a little higher. That hole controls oil flow through the filter so there is not enough flow to drop the oil pressure. With 20-30 PSI of pressure, plenty of oil will flow through the filter, particularly with the engine at normal temperature.
I have a feeling you are used to a full flow filter, this is a bypass filter, it just bleeds a little bit of the oil off. Does yours have a hose in and a hose out? You can plug these off with no ill effects.
tfisher,
Can you post a photo or two of your filter and its "plumbing"?
Here is an excellent Stovebolt.com Tech Tip on by-pass oil filters. There are images and installation instruction sheets in that Tech Tip.
