0 members (), 196 guests, and 1 robot.
Topics128,081
Posts1,056,078
Members48,434
#126615 06/04/2007 3:55 PM
Apprentice
Apprentice
I have a 1949 Chevy one ton that needs its engine compartment hood replaced. I would like to pull the hood off of a 1948 Chevy one and a half ton (1.5 ton) and use it on the one ton.
Will this hood swap work?
"Nothing within the realm of the restoration process shall be alien to my experience"
#126617 06/04/2007 4:45 PM
Anonymous
Unregistered
Anonymous
Unregistered
The rear corners of the two hoods are different. 1/2 Ton to 1 Ton are the same but above that they are different.
#126618 06/04/2007 4:54 PM
Apprentice
Apprentice
Why are the rear corners different? From what I know the cabs are the same and can be interchanged. Logically the connections to the cab must be the same, thus I do not understand why these hoods can not be swapped.
Fenders accommodate larger tires, but the hood need not do so, does it?
Please help...
#126619 06/04/2007 5:28 PM
The cabs are the same, but the grille/hood/fenders are different to cover the largers wheels.
My \'64\'s in the Gallery
Pictures in my Photobucket
1964 C10 Custom Cab 350/700R4
1964 Suburban 350/700R4
1979 Ford F350 4x4 400/c6
#126620 06/05/2007 1:52 AM
sambear
Roughly speaking,The 1-1/2 and larger ad trucks hoods are about 3 inches LONGER front to rear and more gradual in the radius of the fender to hood joint.
They will bolt on at the cowl and fit fairly close,BUT be too far foward to even be close to the hood latch/striker panel.
Hope this helps,Regards
steve sr.
#126621 06/05/2007 4:20 AM
Is the old hood too far gone? Repair might be the easy way out.
~Jim
