7 members (TUTS 59, Gray_Ghost, panic, tclederman, Peggy M, MRMEROTH11, Wickedbass),
122
0
Mod | | | Forums66 Topics128,068 Posts1,055,880 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2018 Posts: 10 New Guy | | New Guy Joined: May 2018 Posts: 10 | https://photos.app.goo.gl/g43OpGR7jhUFjmU02What is this line coming out of the manifold below the carb that is bent back toward the firewall and cut off. 1941 1.5 ton 235 | | | | | Joined: May 2015 Posts: 11,049 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,049 | Does it still have the vacuum wiper motor? How about a vacuum operated 2 speed axle. That might explain the line out of the intake.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: May 2018 Posts: 10 New Guy | | New Guy Joined: May 2018 Posts: 10 | Wiper motor is missing. Mechanical 2spd axle | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | Looks like an early PCV system that went to the draft tube/crankcase tube.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | I vote vacuum port/line.
Have you taken the fitting out to inspect it? If yes, is it an open port (no internal valve)? | | | | | Joined: May 2018 Posts: 10 New Guy | | New Guy Joined: May 2018 Posts: 10 | No I haven't taken that apart. | | | | | Joined: Nov 2017 Posts: 41 Fixer of Things I Probably Broke | | Fixer of Things I Probably Broke Joined: Nov 2017 Posts: 41 | That's where my vacuum windshield wiper motor taps in on my '53 235. (Soon to be where my power brake booster taps in.)
1953 Chevy 3100 Frankentruck with 235 and mostly original bits.
| | | | | Joined: May 2018 Posts: 10 New Guy | | New Guy Joined: May 2018 Posts: 10 | Thanks for all the replies. With your input and the interweb a wiper motor seems likely. | | | | | Joined: Jul 2014 Posts: 1,289 Moderator for Tons o' Fun , Co-Moderator Driveline Forum | | Moderator for Tons o' Fun , Co-Moderator Driveline Forum Joined: Jul 2014 Posts: 1,289 | I also think wiper motor. Plug it and drive on....... I love 60 year old jigsaw puzzles!
Ron - - Dusty53 1954 Chevy 3604In the Gallery Forum "You can't dance with the Devil and then wonder why you're still in Hell." "They will forget what you've said, and they will forget what you have done but they will never forget the way you made them feel." | | | | | Joined: Jan 2013 Posts: 2,232 Moderator: Interiors, Texas Bolters, Name that Part | | Moderator: Interiors, Texas Bolters, Name that Part Joined: Jan 2013 Posts: 2,232 | That is where my vacuum wiper motor was attached. | | |
