| | | Forums66 Topics128,076 Posts1,055,920 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2010 Posts: 384 Shop Shark | | Shop Shark Joined: Jun 2010 Posts: 384 | Hi, the old viking just passed the annual test. But with a comment, change the front brake hoses, and thosa I have new. But also they said the right front bearings made noise, so it needs to be changed. Not urgently but soon.
I tried googling for new ones including gaskets. I have the shop manual and will check for how to do.
But can someone recommend partnr's needed or a good site where these can be found ?
Br /Ulf My Chevy Viking 1959Ulf Hedlund. Eskilstuna. Sweden [email protected]Also: Ford Galaxie 4 dr 1959 Ford Custom 4 dr 1964 Ford Mustang GT 2005
| | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy lastchancetowing, could you please remember to tell us the year and series of truck you are working on? If I am remembering correctly you have a 1959 sixty series, could you tell us if it has the heavy duty front axle or the standard duty one? | | | | | Joined: Jun 2010 Posts: 384 Shop Shark | | Shop Shark Joined: Jun 2010 Posts: 384 | My Chevy Viking 1959Ulf Hedlund. Eskilstuna. Sweden [email protected]Also: Ford Galaxie 4 dr 1959 Ford Custom 4 dr 1964 Ford Mustang GT 2005
| | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy lastchancetowing, the numbers I come up with are 7450335 for the inner bearing this bearing is for a shaft with a 1 3/4" major diameter, this bearing crosses to Bower cup and cone p/ns 25583 and 25519. the outer bearing is 7450336 this bearing is for a shaft with a diameter of 1 1/32" this bearing crosses to Bower cup and cone p/ns 15103S and 15243, hope that helps. | | | | | Joined: Jun 2010 Posts: 384 Shop Shark | | Shop Shark Joined: Jun 2010 Posts: 384 | Thanks, I managed to find all 4 p/ns on Rockauto. My Chevy Viking 1959Ulf Hedlund. Eskilstuna. Sweden [email protected]Also: Ford Galaxie 4 dr 1959 Ford Custom 4 dr 1964 Ford Mustang GT 2005
