1 members (klhansen),
46
Mod | | | Forums66 Topics128,179 Posts1,057,159 Members48,465 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2017 Posts: 13 New Guy | | New Guy Joined: Oct 2017 Posts: 13 | Have a 1954 3/4 ton Chevy Pick-up. Anyone know where I can get front brake shoes? They are different than the 1/2 ton.
Was told by Fillingstation.com they are not made for the 3/4 and suggested I get mine relined?? Which is quite expensive.
DVM
| | | | | Joined: Apr 2017 Posts: 47 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2017 Posts: 47 | I need to do a full replacement on my 55.1 3600. So, I've done some shopping. But, I haven't bought anything, yet. I found OReilly & Advance both show 11" shoes for front & rear. AutoZone shows rear only. Drums are available, too.
1955 Chevy (1st Series) 3600
| | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Are they 12" or 14" front/rear?
11" front/rear was 3100. | | | | | Joined: Jul 2007 Posts: 444 Shop Shark | | Shop Shark Joined: Jul 2007 Posts: 444 | My 1954 3600 has 12 " X 2" brake shoes front & rear .
George '54 3600 | | | | | Joined: Sep 2012 Posts: 222 'Bolter | | 'Bolter Joined: Sep 2012 Posts: 222 | I purchased brake shoes for my 49 3600 from Northwestern Auto Supply in Grand Rapids, Mi. 800-704-1078. They have an amazing inventory of vintage parts. DaveV | | | | | Joined: Oct 2017 Posts: 13 New Guy | | New Guy Joined: Oct 2017 Posts: 13 | Thanks! I called Northwestern Auto and they have the shoes!
DVM
| | | | | Joined: Sep 2012 Posts: 222 'Bolter | | 'Bolter Joined: Sep 2012 Posts: 222 | Good for you. Keep the number. You might need them again. DaveV | | | | | Joined: Jan 2013 Posts: 1,084 'Bolter | | 'Bolter Joined: Jan 2013 Posts: 1,084 | I need to do a full replacement on my 55.1 3600. So, I've done some shopping. But, I haven't bought anything, yet. I found OReilly & Advance both show 11" shoes for front & rear. AutoZone shows rear only. Drums are available, too. Jeffry, Can you please post link to source of drums for AD 3600.
Allen Yeah, well, that's just like, you know , your opinion, man - The Dude
1948 Chevy 3600 - goal Original restoration, Current Stage 1 - Disassembly and getting body in primer 1954 GMC 3100 goal Hot Rod, Current Stage 1 - Get body in primer 1931 Ford Model A 5 window Coupe - Old Skool Hot Rod 1945 Ford 2N Tractor - Runs great 1964 Ford 2000 Tractor - Use it every week 1974 Stingray Corvette
| | | | | Joined: Apr 2017 Posts: 47 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2017 Posts: 47 | Allen,
AutoZone shows 12"x2" shoes and drums. They list only rear. But, I believe they are the same for front and rear. Maybe, someone hear can confirm/deny that.
I tried to copy/paste the link. But, the link only takes you to the main page. Select your vehicle. Then search brakes.
They may even be in stock locally.
Hope this helps.
Jeffry
| | | | | Joined: Jun 2003 Posts: 565 'Bolter | | 'Bolter Joined: Jun 2003 Posts: 565 | Rockauto shows drums available Drums
"Do not walk behind me, for I may not lead. Do not walk ahead of me, for I may not follow. Do not walk beside me either. Just leave me alone, you're starting to freak me out."
1957 GMC 150
| | | | | Joined: Jan 2013 Posts: 1,084 'Bolter | | 'Bolter Joined: Jan 2013 Posts: 1,084 | Doesn't look to me like the Autozone drums would work. Has anyone tried the Rockauto drums?
