6 members (MRMEROTH11, cmayna, David Bush, Hanks custodian, walter74, 1 invisible), 53 guests, and 3 robots.
Topics128,056
Posts1,055,800
#1265843 05/14/2018 12:48 PM
Hi, the old viking just passed the annual test. But with a comment, change the front brake hoses, and thosa I have new.
But also they said the right front bearings made noise, so it needs to be changed.
Not urgently but soon.
I tried googling for new ones including gaskets.
I have the shop manual and will check for how to do.
But can someone recommend partnr's needed or a good site where these can be found ?
Br /Ulf
My Chevy Viking 1959
Ulf Hedlund. Eskilstuna. Sweden
[email protected]
Also:
Ford Galaxie 4 dr 1959
Ford Custom 4 dr 1964
Ford Mustang GT 2005
3B Offline
Hy lastchancetowing, could you please remember to tell us the year and series of truck you are working on? If I am remembering correctly you have a 1959 sixty series, could you tell us if it has the heavy duty front axle or the standard duty one?
Sorry I was in a hurry and forgot. It's a 6500 2 ton from 1959.
Not sure how to see if it has a heavy duty axle or not.
Bad phone, bad pictures:
http://i185.photobucket.com/albums/x264/uffeg/Viking%20Parts/IMG_20180514_205236_zpsu0fwt8fy.png
http://i185.photobucket.com/albums/x264/uffeg/Viking%20Parts/IMG_20180514_205204_zpsthjdtd0o.png
[email protected]
Also:
3B Offline
Hy lastchancetowing, the numbers I come up with are 7450335 for the inner bearing this bearing is for a shaft with a 1 3/4" major diameter, this bearing crosses to Bower cup and cone p/ns 25583 and 25519. the outer bearing is 7450336 this bearing is for a shaft with a diameter of 1 1/32" this bearing crosses to Bower cup and cone p/ns 15103S and 15243, hope that helps.
Thanks, I managed to find all 4 p/ns on Rockauto. smile
[email protected]
Also:
