I just installed a CPP front brake kit on my 41 1/2 ton. Things went well until I checked the track. It is wider than the 7/16 inch I was told it would add to each side. My kit called for 1/4 inch spacers being put between the spindle and the caliper bracket, but on another thread I noticed a picture of a kit with no spacers. Of course, if I remove the spacers the caliper will not be centered on my rotor (#91031063). Does anyone know if there is another 11 inch GM rotor that would allow me to pull those spacers?
