| | | Forums66 Topics128,031 Posts1,055,435 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2008 Posts: 643 'Bolter | | 'Bolter Joined: Apr 2008 Posts: 643 | 1958 GMC1/2t truck 6cyl stock suspension
Wanting to replace the worn shocks. Is there something that will help give a smoother ride?
Danny 1958 GMC stepside GMC 302 six cylinder 3 speed OD trans
| | | | | Joined: Nov 1995 Posts: 5,714 62401 | | 62401 Joined: Nov 1995 Posts: 5,714 | Good morning Danny. It might help if we better understood the question ... How do you define "Smoother ride?" Car like? Or do you just want to stop leaving head-shaped dents in your cab roof ...  ??
~ John A kid raised on Hotwheels, Matchbox and Tonka cannot be reasonably expected to own only one vehicle as an adult. 1949 Chevrolet 3804In the Legacy Gallery | In the Gallery Forum1973 IH 1310 Dump1963 Kaiser M38A12001 International/AmTran RE3000 "Skoolie"2014 Ford E-350 4x4 (Quigley) | | | | | Joined: Apr 2008 Posts: 643 'Bolter | | 'Bolter Joined: Apr 2008 Posts: 643 | Well being that it is the original shocks, leafs etc etc i'm not sure how much better I can get the "ride" without doing a lot of modifying. As I don't plan on changing nothing but shocks.Are there shocks that are better quality than "stock" but won't break the bank? The shocks I see available are Monroe , Gabreil...
| | | | | Joined: Nov 2000 Posts: 1,966 'Bolter | | 'Bolter Joined: Nov 2000 Posts: 1,966 | I don't know, but those 2 companies probably manufacture the majority of shocks sold in the US with any brand name on them.
Professional Novice
| | | | | Joined: Apr 2008 Posts: 643 'Bolter | | 'Bolter Joined: Apr 2008 Posts: 643 | Okay guess I'll go with them-
| | | | | Joined: Oct 2017 Posts: 53 'Bolter | | 'Bolter Joined: Oct 2017 Posts: 53 | I just put 4 new shocks on my 1959 3100 and the difference is noticeable, monroe I believe.
1959 Apache 31
| | | | | Joined: Apr 2008 Posts: 643 'Bolter | | 'Bolter Joined: Apr 2008 Posts: 643 | Ok thanks that’s good to know
