0 members (),
196
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,081 Posts1,056,078 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2008 Posts: 325 'Bolter | | 'Bolter Joined: Jun 2008 Posts: 325 | The nut came off the end of the rocker oiler. Is this nut replaced easily with a flare tool? I've never used a flare tool before. Broken lineBroken line 2Nut | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | All I can see is advertisements.
Thanks Photobucket - one of many photo-hosting sites we have come to love to hate. | | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | Get some spare line and practice, nut must be put on before flaring.
Ed
| | | | | Joined: Feb 2004 Posts: 29,795 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,795 | The line is not flared. It uses a special one-time use nut that crimps itself down onto the tubing. Jerry
| | | | | Joined: Jun 2008 Posts: 325 'Bolter | | 'Bolter Joined: Jun 2008 Posts: 325 | So this is a compression fitting? Are these nuts readily available? Say at NAPA or a bolt supply? Or is this a special order item? | | | | | Joined: Feb 2004 Posts: 29,795 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,795 | The nut itself is the compression fitting. It has a thin tapered front section that bites into the tubing and seals the first time it's tightened. Once the nut attaches itself to the tubing, it is supposed to stay there during later removal/replacement of the tubing in the oil connector. If the nut is installed properly the first time, about 1/8" of the tube or a little more protrudes past the front of the nut, then the tapered portion of the nut crimps itself to the tube as it's tightened..
Every local parts store used to stock those nuts, but that was 50-something years ago when these engines were daily drivers. Someone posted a reference with a part number recently but it was for a 1/4" OD tubing fitting, not the 3/16" OD one that fits the oil connector line. Jerry
| | | | | Joined: Feb 2004 Posts: 29,795 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,795 | Here's a picture of the nut: http://images.oreillyauto.com/parts/img/large/ede/276016.jpgIt's for a 3/16" diameter tube- - - -hard to find these days! The copper tube through the water jacket that goes up to the oil connector on the spray-oilers uses one of these nuts to crimp down on the tube and prevent coolant leakage into the pushrod chamber. There's a mating female adapter that works with the male thread to provide the crimping action as the nut is tightened. I believe this is the female thread adapter that works with it: http://images.oreillyauto.com/parts/img/large/ede/orly_265301.jpg The early-style oil connector with the line that threads into it has a similar female thread to provide the crimp the first time the fitting is tightened onto the oil line. Jerry
| | | | | Joined: Jun 2008 Posts: 325 'Bolter | | 'Bolter Joined: Jun 2008 Posts: 325 | OK, thanks. So it'll be difficult to find. What will happen if I try to re-use the nut? | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | | | | | | Joined: Feb 2004 Posts: 29,795 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,795 | Very good info, Tim! Bookmarked!
I have re-used a nut on occasion, but the crimp doesn't work well on the second try. Ford Flathead V8's used that type of fitting on the fuel pump to carburetor line, and reusing a nut could produce a gas leak, occasionally. Jerry
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | A few of my NAPA stores and Fastenal stores had those threaded sleeves, by the piece (or, pack of 10). They also had the tubing, but if WalMart can get it (for $16 shipped) . . . | | | | | Joined: Feb 2004 Posts: 29,795 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,795 | With a couple of those nuts and the copper line, the through-the-block oil line on a spray-oiler engine can be fabricated for a lot less than the cost of the kits the resto-parts people sell. The female fitting that goes into the block usually doesn't have to be replaced. Jerry
| | | | | Joined: Jun 2008 Posts: 325 'Bolter | | 'Bolter Joined: Jun 2008 Posts: 325 | Gentleman, you are a very big help, many thanks.
This was not in stock, so instead of bringing in one single nut I ordered ten. So now I have a lifetime supply of oil connector fittings! | | |
