1 members (VicZ), 231 guests, and 2 robots.
Topics128,087
Posts1,055,976
Members48,430
#1265526 05/11/2018 7:23 PM
I have a 51 Chev 3100 316 3 speed on the column. When I decelerate in 3rd gear the tranny growls I have another trans I got with the truck but unsure of what year it is. I have it completely disassembled. I want to get a repair kit but want to make sure I order the right one. In Motors Manual it say 53 and newer have 24 needle bearings. I found more than that in the trans so I know someone was in there before. Have 50 of the small long ones. The trans is marked 5 GM 591615 It has C11 verticle above that. The pad next to the side cover is marked JO 96542. 4 bolt side cover and have torque tube. Will the later kits fit or is there different bearings for the 3 speed with the tail shaft..Also what is going on with the existing trans. Shifts great and the synchros work. I either let off real slow or push the clutch in. The trans in the truck is marked 3 GM 59615. Thanks for any help you can supply.
Here is an old post with some information about transmissions with that code: 591615
https://www.stovebolt.com/ubbthread...4-3-speed-transmission-casting-code.html
Read the posts in the whole thread a few times - it might get confusing.
Thanks Will do
Are you sure the growl is coming from the transmission? The symptom you're describing is usually a sign of a failing pinion bearing in the rear end. It starts out as a growl on deceleration, and will eventually start making noise on a pull as the bearings get into worse condition. There will be little or no noise on a "float" where you're neither pulling or coasting.
Just got it apart . The hole in the thrust block has about 1/8 in of play in it. It rocks back and forth. Must of had old grease or rust in it and by driving it itflushed it out. Great call! Now where do i get one of those ?
Aft er cleaning the thrust block up I can see the machining marks inside Maybe suppose to be that way Left carrier bearing is gone. Rollers in the rear end housing. LOL Thanks for setting me in the right direction .
Joe
