Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
3 members (C10 - C90 Bill, cmayna, Otto Skorzeny), 104 guests, and 4 robots.
Topics128,290
Posts1,058,557
Members48,491
#1264806 05/05/2018 2:25 PM
For the shift lever retainer. Anyone happen to know the exact size of these? The nearest guess I have is they are number 6.
Thanks in advance,
Steve
1953 Chevrolet 3100
In the DITY Gallery
Video of the 261 running
1964 GMC 1000
The two pins in the top cover that engage slots in side of shifter lever ball?
In my experience they’re not tapered pins but stepped pins, the smaller diameter then riveted in the top cover.
•1952 Chevrolet 3800 pickup
---All pictures---
Thanks Grigg, you are right, I just removed one. Now to try and find a source to replace them.
1953 Chevrolet 3100
In the DITY Gallery
1964 GMC 1000
Sir Searchalot
Sir Searchalot
If you are sure that the grooves in the ball are not the problem, just use the proper size roll pin. Available everywhere. You may want to get longer than needed. May be easier to work with. Drive in to proper stick out and cut off outside to flush. The hole size vs pin size is very important to tightness. If there is a "step" involved, drill the snout to fit the roll pin. Gotta be real careful with that hole. +/- .003 tolerance for tight fit. Post a pic of the pin you removed (cleaned up and good lighting)
I once replaced the pins by drilling the holes larger for a “roll pin”. In hindsight it wasn’t the best idea, not much or any more difficult to replace them properly like original.
I believe I’ve seen a kit to rebuild/replace the pins. Otherwise you could easily make some on the lathe or even with a file and a drill if need be.
---All pictures---
Sir Searchalot
Sir Searchalot
What is wrong with a roll pin? They are sold by PartsMike for this purpose I believe. Just two roll pins for $5. If it works, it works.
If poster can find a kit or original Pins. Good.
If not: http://www.partsmike.com/index.php/products/623-024-sm420465-shift-lever-pin
Here are the dimensions for lathe made. They are stepped. Dimensions will also help in determining the roll pin size if desired.
Overall length - .715 to .720
smaller diameter barrel length - .523 to .527
Larger diameter barrel length - .183 to .185
Smaller barrel diameter - .247 to .250
Larger barrel diameter - .308 to .310
Everyone need to keep in mine that the sm420 is sloppy/large pattern almost from day 1.
' Offline
Why not just pick up the phone & order some GM NOS Fulcrum Pins .
GM # 4.008 - GM # 590282
https://s26.postimg.cc/bkzn4lqg9/SM_420_Fulcrum_Pins.jpg
Friesen Chevrolet
Sutton , Nebraska
phone: 402 - 773 - 5538
Friesen has ( 70 ) pins in stock
Newton Motors
Glasgow , Montana
phone: 406 -228 -9326
Newton has ( 37 ) pins in stock
These fulcrum pins are a light press fit .
These pins are NOT peened over .
additional PICS
https://s26.postimg.cc/lnx99o0eh/2_a_Fulcrum_Pins_SM_420_GM_NOS.jpg
https://s26.postimg.cc/lnx99o849/SM_420_Top_Cover_Assembly_GM_NOS.jpg
https://s26.postimg.cc/ourstland/2_SM_420_Shift_Lever_Fulcrum_Pins.jpg
George
'54 3600
1954 3600
Now cruising in
The Passing Lane
Sir Searchalot
Sir Searchalot
Excellent George. Now we know one thing for sure, they are not rivets. Lots of folks will appreciate your post in the future. They are on Ebay also.
Wouldnt you know it, I come in from the garage after working on this very thing and read this. I had already drilled it to accept a 5/16" roll pin. Thanks for the link I will order a couple of these for the next one though.
Thanks George!
1953 Chevrolet 3100
In the DITY Gallery
1964 GMC 1000
Perhaps later models were a slip fit.
Just double checked the original ones in my 51 GMC and they are riveted over, and recall the same on the 52 when I replaced them.
Thanks for the part numbers and resources.
---All pictures---
Roll pins are hollow, and brittle since they're spring steel. One overly-energetic shift can break a pin off and drop the broken piece down the shift tower where it will go through those expensive gears like a meat grinder.
Other than that, a roll pin fox is quick, easy, and WRONG! "Other than the iceberg, how did you like the trip on the Titanic?"
Sir Searchalot
Sir Searchalot
5/16" Dia.
1" 0.312"-0.318" 0.062" Rockwell C43 10,800 lbs ASME B18.8.2 50 98296A939 6.28 50 90692A757 8.22
Breaking strength of 5/16 roll pin (McMaster-Carr) Breaking strength is breaking strength, brittle or not.
The stock pin, .25 Dia, even if it's 120,000 psi shear strength, (which it ain't) yields at around 5900 Lbs. Also, the fact there is little or no radius at the step, it has a stress riser built in.
If the roll pins is considered technically brittle:
Brittle, in the strength of materials world, does not necessarily mean it has lower strength. Mostly it connotates to higher strength.
For those who replaced the fulcrum pins, how were the old ones removed and new ones installed? Thanks for any help.
Originally Posted by bartamos
5/16" Dia.
I think what Jerry is getting at is that a roll pin has a specific function, which doesn't include the way it is being used here specifically. However, once the shifter arm is in its saddle and the spring, cup and retainer hood is on, isn't its only function is to keep the assembly together and centered? The shifting action seems to be not connected to these roll pins or guides.
1953 Chevrolet 3100
In the DITY Gallery
1964 GMC 1000
dougs, you have to get a cut off wheel and cut the peened over portion on the outside, then 1/8"punch to knock it out outside to in.
With the replacement nos ones George found, they would have a slight interference fit and would have to be put in from the inside, then some how retained in place then peened over. Anyone have any ideas how one would do that without knocking it back out?
BTW, thank you all for your input, much appreciated.
1953 Chevrolet 3100
In the DITY Gallery
1964 GMC 1000
You could make a little threaded jack to fit inside the tower and lightly press/support both pins (pushing them outward) while peening/riveting the outside ends. Backing up the opposite side with a heavy hammer while riveting the other side with a lighter hammer would also remove some stress from the cast iron tower.
Same could be down with a bar/block of steel fit in between both pins if it were just the right thickness, or few pieces stacked to right thickness.
Or with cover removed rivet one pin at a time using the horn of an anvil or something similar to support the pin from inside.
---All pictures---
Sir Searchalot
Sir Searchalot
A roll pin does not have a specific function. They are used in hundreds of ways. This being one of them. I don't want to step on anyone's toes, but we must try to be semi accurate. The best fix is an actual pin made for that. If a person can get it installed, good luck. If not, maybe a roll pin. You can not peen over a solid pin while in the truck. If you take the top off, it may be possible to install an original pin. I don't know how it's supposed to be installed.
It is called a fulcrum pin. A sort of pivot for the ball and anti rotation for the stick. The shape of the ball keeps it centered. The spring and bayonet cap keeps it retained.The nose of the stick keeps it from rotating also. If pins had no function, they would not wear out.
If the roll pin is correct size and installed in the correct size hole, it will work. Slot facing up.
The particular fix is a decision for any user.
1. Genuine original pin.
2. Roll pin.
3. Donor tranny top
4. Home made pin
5. Any other pin that works and can be installed.
I think the top is a machined casting, so be careful.
Sir Searchalot
Sir Searchalot
Found this from SCOOTER 3/18
IIRC, I grinded off the heads of the fulcrum pins and they slid right out. Make sure to stuff a rag down in the shifter hole so they don't fall inside the trans. Look for some rolled steel pins of the appropriate size at your local hardware store. If needed you can drill out the fulcrum pin holes to accept a slightly larger pin. The rolled pins are also sold by Novaks. They are SM420 experts. thumbs_up
Be advised, nothing you can do will make the shifter feel as snug and tight as a new car shifter. There'll still be alot of play but it shouldn't flop and slop around quite as bad after your new parts are installed.
I think staking on the outside with a chisel, three places, is a better way than peening. Less force on pin. I really think a roll pin is the answer.
Sir Searchalot
Sir Searchalot
Dig this. He didn't say, but a double nut can be used to tighten.
Bart, I hear and understand everything you say, and it makes sense. I have rebuilt 4 of these sm420s now and I have only seen one of the many cores I have looked at with bad pins, subsequently this one had been operated with a broken shift lever spring. So thinking this caused the pin to start to eat away. It has a beautiful top loader so right now I am on your item #2 and the roll pin is installed and I'm going to run it.
1953 Chevrolet 3100
In the DITY Gallery
1964 GMC 1000
Great find thanks Bart. I like this best!
1953 Chevrolet 3100
In the DITY Gallery
1964 GMC 1000
Or some red locktite
1953 Chevrolet 3100
In the DITY Gallery
1964 GMC 1000
Sir Searchalot
Sir Searchalot
I like that the best also. Super good idea. I hope the metal is viable enough to hold good threads. He did use thread locker. The double nut/jamb nuts is just a way to tighten the screw. Then stick out & nuts get cut off. You can see on the threads where he used pliers. That works too. I'm just trying to get in on the act. smile
Your roll pins will be just fine.
Sure there are lots of options, all more or less functional but not necessarily good ideas.
Still in my opinion the original parts and method is the best one.
---All pictures---
Sir Searchalot
Sir Searchalot
Better ideas do come along. Without them we wouldn't have Okie Bushings.
This issue is just a metal pin sticking out of a transmission cover tower. Any way you can get a metal pin to stick out, and function, is A.O.K.
DIY repair without a machine shop is what most of us are looking for. Fixing in place is even better.
