Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
4 members (NJC, baldeagle, carbking, 2-Ton), 31 guests, and 3 robots.
Topics128,005
Posts1,055,254
Members48,418
#1264616 05/03/2018 8:59 PM
Need some help. This is what it says in the Tech Tip:
Step 8 — To check the backlash, mount a dial indicator on the carrier and check the backlash between the ring gear and the pinion. It should be between .005” to .008”. If the backlash is more than .008”, loosen the right adjusting nut one notch and tighten left adjusting nut one notch. If less than .005”, loosen the left adjusting nut one notch and tighten the right one one notch.
While I have the cover off the Pinion to replace the seal. Can't I just measure the free play in the pinion shaft.
Or how is the above step 8 accomplished. In terns a beginner would understand.
Julian Carter
1970 Triumph GT6
1967 Triumph TR4A
1952 Chevy 3600
1948 MG-TC
The pinion shaft is the one the universal joint flange is attached to. You need to measure the movement of the ring gear, not the pinion. Use a magnetic base dial indicator or one with a C-clamp mounting attached to a long bolt screwed into one of the cover attaching bolt holes and position the stem of the dial indicator as close to 90 degrees from the movement of the ring gear as possible. Measure the amount of slack there is while rocking the ring gear forward and back. Unless the slack is WAY out of specification, don't mess with any adjustments. You are almost guaranteed to create a gear whine by changing the wear pattern the gears have established over decades of operation. I'd consider anything under .025" or so of backlash to be in the "DON'T MESS WITH IT" category. More than that- - - - -go shopping for another third member- - - -it's worn out!
Thanks Jerry I believe I can do it now. I found a large amount of free play just turning the pinion. Now I'll measure the play in the Ring gear.
Julian Carter
1970 Triumph GT6
1967 Triumph TR4A
1952 Chevy 3600
1948 MG-TC
I'm curious what you find. Sometimes play can be deceiving and isn't as bad as you think once measured.
1953 Canadian GMC 9314 w/ (factory) Chevy 235
Be sure to hold the pinion flange some way to keep it from turning and giving you a false reading on the ring gear movement. Apparent slack can add up from several places- - - -axle and spider gears, splines, and cross pin clearance, even if the ring/pinion backlash is correct, or only slightly excessive.
Thanks Jerry, I found my backlash to be very good. .006 Once the pinion and ring gear started to make a clicking sound.
Everything became easier.
Julian Carter
1970 Triumph GT6
1967 Triumph TR4A
1952 Chevy 3600
1948 MG-TC
