0 members (), 40 guests, and 2 robots.
Topics128,030
Posts1,055,428
Members48,422
#1264508 05/03/2018 1:34 AM
I Have a 1947 3/4 ton that still has the lever shocks. I want to upgrade to modern shocks. Anyone use the kits from JCarter or others? Also, anyone have a photo of hoe the rear mounting brackets attach to the axle/frame? Thanks!
Dachshund #1264509 05/03/2018 1:49 AM
Here you go.
The upper brackets are identical front to rear. The rear's mount with bolts in only 3 of the 4 holes in the bracket. The lower mount is part of the spring mount u-bolt plate.
Dachshund #1264526 05/03/2018 3:24 AM
Great photos, just ordered my upgrade from Classic Parts!
Like Kevin stated the upper brackets front and rear are the same.
Classic parts shocks are Monroe's!!
Jeff
