2 members (MikeStone1953, Guitplayer), 53 guests, and 5 robots.
Topics128,269
Posts1,058,399
Members48,485
#126438 05/24/2007 2:29 PM
I just got my hands on a 41 Grille in great shape at a swap meet but some of the vertical bars on the lower portion need strengthened at the joints a bit and was wondering if they should be mig welded or is it easier to braze. The grille is not chromed but it seems it's a very thin gauge steel. I've gotten pretty good at mig welding sheet metal and was wondering which type of welding to do. Thanks. Bob T
bobt,
MIG welding focuses the heat on a very small area, and does it quickly. Brazing requires you to heat the area to nearly a red color before applying the rod. If you have any .023 wire, I think the MIG process would result in less warp.
Stuart
bobt:
This is a job for a good TIG welder. TIG is superior to other welding processes on light gauge sheet metal. Good luck with your project.
Tony
