0 members (), 124 guests, and 1 robot.
Topics128,157
Posts1,056,876
Members48,458
Good afternoon,
I just bought a 1946 Chevrolet 1 1/2 or 2 ton truck. It will be delivered to my property tomorrow (04/17/18).
Here is what I know or at least what I think I know.
This truck has 2 transmissions and 3 shifters. The secondary transmission has 2 linkages going to it.
There is an extra pedal about 2 1/2" in diameter to the right side of the gas pedal (I am guessing this is the starter?)
The cylinder head appears to be from a 50's model 235 casting number 383G6848
The wheel base (center of front axle to center of rear axle) is about 178" but I was on the short end when measuring.
Duel rear wheels.
The identification number appears to be the engine number DEA2016
This truck was said to have been on the road daily in the 90's and running when it was parked about 3 years ago
Anyone have any further thoughts based on what I have so far?
Don't fear the competition, BE the competition
Big Bolt Forum Moderator
welcome to the site! It is hard to tell in your pics, is the dust cover (covering the wheel bearing and spindle nut) on the front wheels held on by 5 bolts? If so, it is a 2-ton.
yes, the small pedal to the right of the accelerator is a starter stomp pedal.
Nice looking truck!!
Mike
I do recall seeing 5 bolts on the front wheels. Delivery got delayed but once “Hoss” makes it here I can take better pics and get the passenger side hood open. Hopefully those things will help.
How does everyone feel about purity in these old beasts? I am considering going with a candy apple red with black fenders.
24601
24601
Welcome TodS! Looks like a nice truck. And I saw in the other posting you were invited to Homecoming(starts on the 27th over here in So. MD).
The experts will be able to tell you more about your truck if we can see pictures of the whole engine, if you can provide the engine block casting number (forward of the distributor) and some pictures of the second transmission and linkages. If that is an overdrive or a secondary, there are some folks on here who can tell you a lot about it.
And as far as painting your truck red with black fenders ... I think most of us ... with intense therapy and work ... will, in time, get beyond our initial outrage, revulsion and violent urges and may even come to accept such a color combo... wink
~ John
1949 Chevrolet 3804
1973 IH 1310 Dump
1963 Kaiser M38A1
2014 Ford E-350 4x4 (Quigley)
Hello, TodS,
Welcome to Stovebolt.com
Nice truck - they painted them a variety of ways from the factory, supposedly at no-cost/minimal-cost.
(Black was the standard color for fenders, but, they could be body color, if requested.)
http://chevy.oldcarmanualproject.com/chevyresto/4647.htm
Engine Serial Number:
DEA2016
DEA = 235 engine in a 6xxx series truck (6702, 6100, 6400) from Flint, MI engine plant
2016 = 1016th engine out of the plant that year
http://www.1954advance-design.com/chev-specs/1946-Chevrolet-t-ser.jpg
http://chevy.oldcarmanualproject.com/chevyresto/4677.htm
Welcome to the Bolt!
That IS a nice looking truck! I've always liked that style of truck.
I like the color that it is now, but it's your truck, not mine. Do whatever you want.
Rich
1947 Loadmaster
1947 Chev. Loadmaster
1959 Chev. Viking 40
Well, I am still waiting on “Hoss” to be delivered. He was supposed to arrive Tuesday but there is a delay. Now it looks like early next week. I have so many questions about this truck that I first need access to it so that I can ask the correct questions along with photographic back up. Time is not me friend here as almost every weekend in May is spoken for with Harley trips/events.
Would love to go to Homecoming but if that is my first weekend available to start on Hoss that will win out. I cannot wait to see if I can make her run.
Nice looking truck
Welcome to the the site.
I also just got a 46 2-ton, lots of fun to drive 🎩
Tophat
1950 4400
1949 3100
1946 2 ton flatbed
1949 3800 panel
1952 3100 panel (newest one)
Queen Creek AZ
OK, So "Hoss" FINALLY got delivered today. Here is the information I have after a quick lookover (not in order)
(1) Both doors will need lower patch panels
(2) All glass and at least the windshields molding will need replaced
(3) I need to invest in PB Blaster
(4) I need a cutoff wheel attachment for my die grinder (the passenger side hood is tack welded shut)
(5) There is a bit more rust than I thought but still not too bad
(6) The frame has been cut and welded about 1/2 way back from the cab to the differential (looks like good work though)
(7) The numbers on the secondary transmission (or whatever it is) are SCC C3C - 15 as best as I can tell
(8) The numbers on the primary transmission are GBT 7222
(9) The numbers on the differential are (these may be partial) 5.64.1 8 then below that 6.36 3R2K37 as best I can tell
(10) This appears to be a 2 speed differential
(11) There are 6 hub bolts
(12) The shifter closest to the driver's door has 1-N-2 with R to the left and down and on the right has 3-4 (this appears to go to the differential)
(13) The far right shifter has a small lever just below the knob
(14) The middle shifter seems to have 2 positions forward (toward the engine) and back (toward the seat)
(15) The wiper system needs a lot of attention
(16) New window regulators and door handles are in order
(17) The shifter that appears to be attached to the differential seems to be stuck (not sure if it is the linkage, cable or internal to the differential)
I have attached the 5 pics I am allowed any input would be greatly appreciated as to what I actually have here
Any thoughts on the value of this truck in this condition would be nice. It is supposed to run but lets assume it does not
Here are some more pics, not sure what the knobs on dash are for or the 2 toggle switches (prolly added later)
3B Offline
Hy TodS, your truck is a two ton as evidenced by the six bolt cap in the center of your front wheel, the shifter with the small lever is the one for the main unsychronized four speed transmission. some of the early two speed rear axles had cable/rod shifters, hope that helps.
As 3B mentioned, the shifter with the lever is for the main transmission. The little lever is the reverse lock out. You lift the lever to put it into reverse--to the left and down (toward the seat).
I can't speak to all those other shifters. Presumably one is for the two speed axle, but that's just a guess.
Rich
1947 Loadmaster
Crusing in the Passing Lane
Sometimes the 2 speed rear shifter is on the left side of driver's feet. Could also be a Brownie shifter. Easy to check out-look in driveline.
Ed
Congratulations, cool truck!
