1 members (baldeagle), 158 guests, and 2 robots.
Topics128,110
Posts1,056,241
Members48,437
#1262472 04/13/2018 11:48 PM
I have painted my 63's frame with POR-15 and am trying to figure out what I have to do to topcoat it (since the POR needs to be protected from UV rays). I bought some black paint from NAPA (part number PCC135B, PDS attached). On a properly prepared surface, this stuff doesn't need a primer, so I didn't even think about applying it over POR. There is a "tie coat" primer that your supposed to put over POR before you topcoat it, but I don't know if I need it for the NAPA stuff or not. I tried to do some research on it, but I'm just spinning my wheels, so I thought i'd ask you guys.
Thanks in advance!
Cedric L. Brown
1963 Chevrolet C-10 long stepside
[url] https://photos.app.goo.gl/hE3wcWiY5FENFwfK2 [url/]
You can top-coat/overcoat/primer POR within a certain short period of time.
If outside that period of time you need to apply a "tie" coat.
Will your frame "see" much UV-rays/sunlight?
From POR website:
- Topcoat when first coat is dry but with slight finger-drag remaining, usually 4-5 hours.
- TO TOPCOAT A FULLY CURED POR-15 SURFACE:
Wet sand with 320 grit until gloss is dull, then paint, or use POR-15 Tie-Coat Primer directly on the cured POR-15 surface, then topcoat as desired.
Tim is correct.
Also, the guys at POR15 will answer the phone when you call and tell you exactly what you need to do, based upon your circumstances. They are just a phone call away...
~ Dave
I just try to not park my truck upside down.
Ed Miller
'58 Apache short Fleetside half ton Napco
Falls City, OR
