2 members (Steelonsteel, Wooley), 141 guests, and 2 robots.
Topics128,167
Posts1,057,020
Members48,458
On the road again
On the road again
I just bought a 53 3100, it has a Holley-weber 5210 carb, I would like to go back to an original carb. what do I have to do??
Presumably, the original 216?
You do not have a "core" of the original?
CHevs of the 40s - approximately $350
Classic Parts - approximately $280
Check Jim Carter Truck Parts
Post the engine serial number that is pressed into the block to the rear of the distributor.
A 235 was not the standard 231 truck engine in 1953.
You should identify the engine before looking for a carburetor.
On the road again
On the road again
At the time of the restoration they upgraded to a 235 engine......
You might as well ID the engine year and application?
The Engine Serial Number will hold/provide some of that information.
