1 members (Ole49GMC), 109 guests, and 0 robots.
Topics128,115
Posts1,056,292
Members48,439
OK, this is for you Electrical Engineers out there.
’50 3100 converted to 12v with Alternator.
I don’t need nor want the rheostat (dimming) feature on my instrument panel lights.
As it turns out, last night my instrument lights when out altogether, so when I got home I pulled out the light switch and discovered
the spring that the rheostat slides (back & forth) on to create the dimming feature had broken.
So, rather than buy a new Headlamp switch assembly, what I’d like to do is by-pass the rheostat feature and hard-wire it so that when I turn on the Headlights,
the Instrument panel lights also come on bright (by-passing the rheostat).
Looking at the photo attachment, (it's the original type switch)
….would it just be a matter of putting a jumper between “Dash” and “Head”?
Or is there more to it than that?
Pretty much all I know about electricity is… I flip a switch and a light comes on :-)
Thanks, Jim
Put the dash lights over to the tail lamps terminal. This way you have dash lights when the headlight or the park lights are on.
1953 Chevrolet 3100
In the DITY Gallery
Video of the 261 running
1964 GMC 1000
thanks ss,
?? just bring the "Dash" wire over to the "Tail" terminal?
Jim
