4 members (Guitplayer, MickeyP, Ponchogl, ShopRag), 90 guests, and 1 robot.
Topics128,035
Posts1,055,564
This is hard to explain so bare with me.
I have finished all my metal work and reasembled the truck to align panels. My seams are good and alignment coorrect. However I noticed that my truck and all others I have seen have a problem, the box top rail is on the same plain or line although at a diffent level than the door and front fender crease/line. this looks good and helps to give the empresion of speed while standing still. The rear fender crease/line however his high in front and does not follow the same plain or line of the box top and front door and fender. I wish I could figure out how to attach a photo but for now if you did a google search on [1955 chevy stepside truck] you will find many side profile pictures to look at, follow the crease/line of the rear fender and you will see what I mean. I plan on cutting and lowering the front of the rear fender to get it to follow the same plain - line as the top of box and front door and fender. Has anyone else noticed this and did you correct for it, and if you did how did you do it and how did it turn out. thanks
[img]http://www.truckinweb.com/brandpages/chevy/0301tr_1955_chevy_stepside_pickup_truck/photo_03.html[/img]
Dan...Please try to get a pic of this problem..posted
HURRY UP AND WAIT 55 235 3/4
Dan - don't attach pic, link it [use URL button]
talk about picky! if every truck you see has the same problem, what makes it a "problem" rather than a design feature? how do you know your cab is mounted 'plumb'?
I think what yer seeing is an illusion, due to the difference in the clearance of the top of the fender from the rail at front and back ... same as the appearance in that particular pic that the box step is bent down at the front outside corner because of the shadow ... I hold a straight edge up to the feature line on that pic and it is plumb and parallel .... and here\'s a side shot of a friends truck, straight edge works on it too
in fact, if I hold a long straight piece of 1x2 up against the fender of my [rough] stepside, it's nearly perfect parallel with the cab crease ohwell
the top of the box actually continues the line of the front fender tops and the bulge/roll on the door above the feature line .... and the impression of 'speed' is imparted via the slope of the fender openings and of the doors ..... an advertised part of the original design decision grin
red 58
my cab is mounted with new mounts and set to factory spec which I believe is 1 7/8 from top of frame to underside of cab. I used a lazor level to get the line of the front and then moved it down to the line of the rear and the slope is different. your truck is the best i have seen. Ill keep working on it and if I can post a pic. thanks
the problem is Dan, that the factory specs were a guideline, and the eyeball of the line crew/inspectors was the final decider - if one part didn't immediately fit and look right, they could set it aside and grab another, but wasting time wasn't in the picture .... also the cab/front was assembled on one line, the box on another, the 2 assemblies then dropped onto a completed chassis .... and you have a long box? the design was prolly done for a shortbox, maybe lengthening things introduced a little variation into the mix
laser level to what? the original stance of the truck is a slight rake, the fender line flows around different curves front and back, and there's actually a slight crown to that line on the fender .... the body side bulges out, the bed might have shims/pads under front and back, or not, the new cab mount pieces you used might be slightly different than the originals .... getting the gaps perfect on the front clip may have required the cab to be off a bit .... and on and on
remember that we're dealing with very low cost, mass produced consumer goods here ... workin mens trucks, not precision engineered show machines, I doubt they specified that feature line had to be aligned perfectly - shim up the back of the box to split the difference, don't get an ulcer over it! grin
I won't get the ulser, I have new bed rails and shims as well, I will try to shim first. thanks for the info.
