5 members (Gib70, 3B, MickeyP, Jon G, 1 invisible), 85 guests, and 1 robot.
Topics128,050
Posts1,055,648
#1262279 04/12/2018 2:28 AM
I have a 51 chevy 3100 and built the motor a bit bigger than expected so I would like to change out the rear end or a possi track. Right now it has a 55 stock single track. I was wondering if there is a rear end I can get that is the right width to fit with out a lot of work. Thanks for helping.
hebert2756 #1262291 04/12/2018 3:38 AM
Sir Searchalot
Sir Searchalot
Herbert, that would, of course, not be a 6 lug. If that's what you want.
hebert2756 #1262298 04/12/2018 5:18 AM
We have used the Colorado/Canyon rear both drum and disc. Can't remember if the 2wd or 4wd one is the perfect width (61"). Has 6 lug pattern on 5.5 bolt circle. The Isusu Trooper is also 6 lug and just a tad narrow which can be cured with wheel offset or spacers. It has a Dana 44 so any gear ratio or locking/open is available at a good price. If you want one that is a straight bolt in where nothing has to be cut and re-positioned with no welding involved---it doesn't exist or it hasn't since 1949 when I first started.
Evan
hebert2756 #1262331 04/12/2018 4:03 PM
I went this way, but that's just me.
mick53 #1262349 04/12/2018 11:31 PM
Yes I want 5 lug so I will also have a bigger choice of wheels. I don't care if I had to cut and weld mounts to the rear end. I just didn't want to have to cut down on width.
hebert2756 #1262374 04/13/2018 2:33 AM
A GM 10 bolt 60 1/4 inches fits well. Lots of after market parts to made it stronger if you need.
mick53 #1262432 04/13/2018 5:25 PM
Showoff😎
RonR
1970 340 Duster
1964 CJ5
hebert2756 #1262683 04/16/2018 2:21 AM
Yes, he is a show off, and he feeds his dog too many biscuits. smile
hebert2756 #1262748 04/16/2018 6:20 PM
Crusing in the Passing Lane
GM 14 bolt ff come in 6 lug, that way one could keep 6 lugs all around.
Ed
EdPruss #1262804 04/17/2018 1:10 AM
Ed
Ed, are the lugs the correct diameter for the old rims? I have seen some six lug axles in the junk yard, but the lugs were too big in diameter. I don't know what axle I was looking at.
52Carl #1262818 04/17/2018 3:34 AM
I currently have 9 Basset Hounds. Mommy dog Daddy dog and 7 6 week old puppies
hebert2756 #1262914 04/18/2018 2:43 AM
14 bolt ff 6 lug axles are 6 on 5.5. Some GMC 1 ton are 6 on 7.25 'artillery' wheels.
Ed
EdPruss #1263108 04/20/2018 1:21 AM
Ed
What about the diameter of the lugs themselves? The threaded lugs.
hebert2756 #1263177 04/21/2018 12:23 AM
You will have to check, however, most wheels have large bolt holes, you sure do not want .5" bolts. Check the holes in your wheels?
Ed
