1 members (lumbersawyer),
84
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,055 Posts1,055,782 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2017 Posts: 32 'Bolter | | 'Bolter Joined: Oct 2017 Posts: 32 | Ihave a 52 chevrolet 4600. I have had the rear cylinders rebuilt they were stainless lined with new seals. I have fitted them. I have also cleaned and fitted the shoes.I have a problem in that even though i have the adjuster wound right in drivers side rear is not letting off properly it appears to be holding on. I have jacked up the truck to test and the passenger side lets off fine. Does any body have any ideas. Thanks Howard. | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy Howardwade, have you done any other brake work? If you have not adjusted your rear brakes you may not have a good bleed and your cylinder pistons may be being pushed out so far they might be hanging up or binding. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Howard,
If your 1952 4600 has brake "booster" equipment, I think that the bleeding procedure and bleeding equipment are different from other series/equipment trucks.
| | | | | Joined: Dec 2002 Posts: 2,549 'Bolter | | 'Bolter Joined: Dec 2002 Posts: 2,549 | 4600 series ? Do you mean 6400 series 2 ton truck ? Maybe 4100, or 4400 series 1 1/2 ton truck ? | | |
