6 members (Hotrod Lincoln, klhansen, Mike B, Otto Skorzeny, IHPWR, Jims46), 50 guests, and 2 robots.
Topics128,030
Posts1,055,423
Members48,422
#1262545 04/14/2018 7:55 PM
Hello Guys ( & Girls ), I was wondering if it is possible & economical to box the front frame section on a 36-37 chevy pickup & weld on mustang A arms & coil springs as the ifs kits are very expensive. Has anyone of you done this. My flawed thinking 😜 is the ride & handling would be far supierior. Thx for your info.
bebop40 #1262586 04/15/2018 12:56 AM
before anyone can answer your question, what is your plan for this truck? Ie daily driver, hotrod, Sunday driver, etc.
Chris
Having a '37 truck with all new front steering, new tires, front sway bar, and new custom made leaf springs, I will challenge any MII front suspension to ride any better. I can drive 30 mph or 75 mph all day long and feel safe doing it. It sure won't look as good in my opinion.
As far as economical, rebuilding the original suspension is the way to go. On the other hand, if you want ifs, there’s plenty of options out there when it comes to MII.
Speedway, CPP, and others all have economy kits. I recently purchased an “economy” crossmember from CPP and control arms from Jegs. The crossmember is top notch, I may clean up some welds on one spring hat, but it’s more of a cosmetic thing than anything. For a little over $200, I can’t complain. The control arms were a good deal too, I may swap the ball joints out, but I don’t have anything bad to say about the quality.
I haven’t seen anything out there for 36 trucks, but there seems to be a number of 37-40kits available.. If nothing else, you could buy a universal crossmember and build it out from there.
1954 3600 Chevy Truck
"The Fake Truck"
More pix on Photobucket
bebop40 #1262663 04/15/2018 11:21 PM
Rare Parts Inc. distributes a set of original-style tie-rod ends. I have a pair on my Suburban and they are easy to install and easy to adjust.
Rare Parts Right Outer Tie Rod End 1933-1959 Chevy GMC Trucks 1933-1936 Pontiac 25128
SKU: RPI-25128
UPC: 699288251282
http://fcrcmachine.com/rare-parts-l...hevy-gmc-trucks-1933-1936-pontiac-25129/
Rare Parts Left Outer Tie Rod End 1933-1959 Chevy GMC Trucks
SKU: RPI-25129
UPC: 699288251299
other sources
It has been mentioned many times, but it warrants repeating. Before one goes to the great expense of non-reversible modifications to these trucks, one should drive the truck with the original style setup after one rebuilds all of the components involved. You might be surprised how nice it rides as designed. Most complaints of ride quality are not from the original design, but rather from disrepair of old components.
Carl
Bravo Carl! I was so pleasantly surprised on my ride quality after putting the rebuilt 53 suspension in action. Absolutely no complaints!
1953 Chevrolet 3100
In the DITY Gallery
Video of the 261 running
1964 GMC 1000
52Carl #1262702 04/16/2018 9:58 AM
1. Before one goes to the great expense of non-reversible modifications to these trucks, one should drive the truck with the original style setup after one rebuilds all of the components involved.
2. You might be surprised how nice it rides as designed.
3. Most complaints of ride quality are not from the original design, but rather from
4. disrepair of old components.
Carl
ditto
ditto
ditto
ditto
