0 members (), 67 guests, and 3 robots.
Topics128,055
Posts1,055,782
#1262553 04/14/2018 9:12 PM
Ihave a 52 chevrolet 4600. I have had the rear cylinders rebuilt they were stainless lined with new seals. I have fitted them. I have also cleaned and fitted the shoes.I have a problem in that even though i have the adjuster wound right in drivers side rear is not letting off properly it appears to be holding on. I have jacked up the truck to test and the passenger side lets off fine. Does any body have any ideas. Thanks Howard.
Howardwade #1262580 04/14/2018 11:45 PM
3B Offline
Hy Howardwade, have you done any other brake work? If you have not adjusted your rear brakes you may not have a good bleed and your cylinder pistons may be being pushed out so far they might be hanging up or binding.
Howardwade #1262581 04/14/2018 11:51 PM
Howard,
If your 1952 4600 has brake "booster" equipment, I think that the bleeding procedure and bleeding equipment are different from other series/equipment trucks.
4600 series ? Do you mean 6400 series 2 ton truck ? Maybe 4100, or 4400 series 1 1/2 ton truck ?
Spanky Hardy
More pictures on Photobucket
1950 GMC 250 1-Ton
