Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
2 members (Rusty Heaps, panic), 51 guests, and 3 robots.
Topics128,009
Posts1,055,293
Members48,419
#1262253 04/11/2018 11:19 PM
Got my 56 out for the first time yesterday(longer than around the block) The truck wanders(wife was behind me and wondered what was going on) Checked bearings,and front end partsand all SEEM tight. Any thoughts??
Midpiner #1262254 04/11/2018 11:30 PM
Have you adjusted the screw on the engine side of the steering box? It should be a screw inside of a nut. You loosen the nut, tighten the screw the amount needed and retighten nut. You can also add more lube into the steering box. I would look at the manual if you have questions. I added a sway bar on mine to assist also. I am sure someone will jump on here and explain in better detail.
Chris
Midpiner #1262257 04/11/2018 11:41 PM
What type tire (radial, bias ply) and what size tire?
What psi? too high and you "wander"; too low and the steering is hard
Have you ever set/checked the "pre-load" on the steering box?
http://chevy.oldcarmanualproject.com/shop/1955truck2/55ctsm0903.htm
You can use a light-weight fish scale from Wal-Mart/etc for the "J-544 Steering Gear Checking Scale)
Playing with the air pressure and adjusting the steering gear pre-load made a big difference in my steering on an earlier truck.
Last edited by tclederman; 04/11/2018 11:43 PM. Reason: this post was submitted why Chris was posting.
Midpiner #1262259 04/11/2018 11:52 PM
Tire size is 215/70/16,about 35 psi Radial Will get the manual out and check it.Will check the screw etc. on steering box.Thanks
