5 members (TUTS 59, Bill Hanlon, 68ironhead, 66flea, 1 invisible), 98 guests, and 3 robots.
Topics128,081
Posts1,056,321
Members48,442
I have a 1951 3100 and have a different 3 speed transmission and rear axle. The case number is GM 15, 3354726, E245 and the tailpiece is GM 8, 8866722, E226. The rear diff is another story. I looked for numbers but only could find the front passengers side has a F1 (stamped) and the front drivers side has a cast 331 and a clock face. I’m hoping members can help solve the story of this trans/rear axle. thanks
Crusing in the Passing Lane
Can you send us a picture of the trans. and diff?
Ed
Clarify please. Is it a Torque Tube or a later open Driveline transplant?🛠
Open driveline.
As Ed posted, post some photos. The procedure is in the Stovebolt Image Posting Policy shown in the left margin of this page.🛠
Thanks. I tried to post pics but when I used the manager, it just spins and doesn’t load. I’m using an IPad Pro and don’t know where to find the picture size to see if I exceeded the size limit. I took pictures of the transmission and rear diff. Help?
1. You have to learn how to downsize your photos to 300K or less.
On an iPhone or iPad, you can accomplish this by mailing the photos to yourself, and choosing a smaller photo size.
2. However, iPad/iPhone photographers: unless you can read/save those email photo-attachments on a computer/device with a file-directory/file-manager, you will not be able to "select" your photo-file OR drag-and-drop your photo-file using the Stovebolt image/photo Attachment Manager.
If I am incorrect, would an iPhone/iPad user please tell us how to attach photos here (from an iPhone/iPad)?
Added/edited later: there is now a "Files" feature in Apple iOS for iPad/iPhone. It works with the Stovebolt image/photo Attachment Manager.
I thought that that was my problem I’ve been trying to post and all I uses an iPad so now I know I have to go to the computer at work since I don’t have a computer at home thanks for that update and I will now post some pictures when I get on my work computer 😁🎩🎩
Tophat
1950 4400
1949 3100
1946 2 ton flatbed
1949 3800 panel
1952 3100 panel (newest one)
Queen Creek AZ
Tim, you are correct.☹️
So just found another clue. Rear wheel cylinders have. The number 1” 5450649. Still trying to post pics. I haven’t given up yet!
I found a number on the pinion gear. #3740674-10-39-GM. Also a 2-12-57.. Does that mean it is a 1957 rear end?
