1 members (Truckrolet),
154
Mod | | | Forums66 Topics128,149 Posts1,056,818 Members48,456 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2009 Posts: 235 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 235 | Hey all, putting the Langdon hei in '56 235 from a bel air. My question is about the nice little plastic connectors that connect the distributor to the coil and hooking up the #10 wire. The instructions say to use a #10 wire and connect it to the same side of the coil as the pink wire (+). The pink wire has a really nice little plastic, female plug that hooks up to the coil. How specifically do I connect the #10 wire?
Do I cut the pink wire and splice in the #10 (which doesn't sound right since the pink wire is not a #10)?
Do I take the crimp apart, remove the pink wire, add the #10 and re-crimp?
Maybe I'm over complicating, but seems like there should be a more factory looking method to adding that wire when it looks so nice out of the box.
Then I'm curious about seating that distributor. I have the engine at TDC, but when I just initially set the distributor in it is about a 1/4" from setting flush against the block. I haven't messed anymore with it, just wondering if I'm missing something there too.
'53 Chevy 3604 Five Window Cab ('56 235)
| | | | | Joined: Feb 2004 Posts: 29,850 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,850 | Drop me a PM, or an email. I don't feel like debating the Drama Llama on the open forum. Jerry
| | | | | Joined: Feb 2004 Posts: 29,850 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,850 | Not there yet- - - -give it a few more minutes. Sometimes my ISP gets a case of the slows! Jerry
| | | | | Joined: Jun 2009 Posts: 235 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 235 | My email is down now - check pm
