| | | Forums66 Topics128,078 Posts1,056,029 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2006 Posts: 428 'Bolter | | 'Bolter Joined: Feb 2006 Posts: 428 | Hi Guys and Gals, I pulled my seat frame for clean up and painting. In the center about 8 inches back from the front skirting is a hole in the floor. It looks to be roughly 1/2 inch. Can somebody tell what it is for? Oh BTW it looks to be original not something PO did. | | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Jimmie D,
I can't find your year rig listed anywhere, but my AD has a hole too, and it's plugged with a small rubber plug....maybe a drain hole in case the cab needed a flush!
Stuart | | | | | Joined: Feb 2006 Posts: 428 'Bolter | | 'Bolter Joined: Feb 2006 Posts: 428 | Aromarc, sorry, I have been around here so much I guess I expect everyone to know what I drive. It is a 52 1/2 ton. It has a 56 235 motor in it. I suspected that the hole was/is a drain of some sort. I guess from your reply you checked my profile. I have needed to update that for some time. Thank you for reminding me Jimmie D. | | | | | Joined: Aug 2005 Posts: 442 'Bolter | | 'Bolter Joined: Aug 2005 Posts: 442 | I have the same hole in my '50. Figure it's a drain plug, probably if the gas tank develops a big leak (the Captain has turned on the NO SMOKING sign!)
I've always thought to Rhinoline under the seat, plug up the hole and use it as a ice cooler!! Keep your buns cool in the hot Texas heat! | | |
