3 members (tesa, Bill Hanlon, Gray_Ghost), 76 guests, and 0 robots.
Topics128,076
Posts1,055,925
Members48,430
#126175 05/13/2007 8:49 PM
Hi Guys and Gals,
I pulled my seat frame for clean up and painting. In the center about 8 inches back from the front skirting is a hole in the floor. It looks to be roughly 1/2 inch. Can somebody tell what it is for? Oh BTW it looks to be original not something PO did.
#126176 05/13/2007 10:26 PM
Jimmie D,
I can't find your year rig listed anywhere, but my AD has a hole too, and it's plugged with a small rubber plug....maybe a drain hole in case the cab needed a flush!
Stuart
#126177 05/14/2007 1:41 AM
Aromarc, sorry, I have been around here so much I guess I expect everyone to know what I drive. It is a 52 1/2 ton. It has a 56 235 motor in it. I suspected that the hole was/is a drain of some sort. I guess from your reply you checked my profile. I have needed to update that for some time. Thank you for reminding me Jimmie D.
#126178 05/14/2007 4:46 PM
I have the same hole in my '50. Figure it's a drain plug, probably if the gas tank develops a big leak (the Captain has turned on the NO SMOKING sign!)
I've always thought to Rhinoline under the seat, plug up the hole and use it as a ice cooler!! Keep your buns cool in the hot Texas heat!
