9 members (Rusty Heaps, 1955 1 Series, 55shaker, 3800GUY, RaNfLaS, tclederman, Otto Skorzeny, wilbur53, FAST55), 157 guests, and 0 robots.
Topics128,104
Posts1,056,201
Members48,436
#1261655 04/06/2018 3:59 AM
Fox
Offline
I keep slowly picking away at my list and today I think I burnt up a horn. I have a 6 volt horn installed. I put in a 12 volt relay along with it. I wanted to test it, so I hooked up my wires to the relay, horn and power. Then, I jumped the wire on the steering mast to simulate pushing the horn button. I gave the horn 3 VERY short blasts. Perhaps 1/2 second each, about a second apart with loud HONKS! Then, nothing a click click from the relay. Did I fry something?
Thought I’d ask for help before tackling it alone.
Thanks.
1970 Chevrolet C10
1950 Chevrolet 1-Ton Dually
"Ole Red Girl"
More pictures here
Parts trucks-
Fox #1261661 04/06/2018 9:32 AM
Well, Did Ya smell any smoke? Sounds like the relay is working so I'd go ahead and open up the horn and look for trouble inside.
Julian Carter
1970 Triumph GT6
1967 Triumph TR4A
1952 Chevy 3600
1948 MG-TC
Fox #1261665 04/06/2018 11:38 AM
Ex Hall Monitor
Ex Hall Monitor
Assuming you are running 12 volts. If you damaged the horn I seriously doubt it was from using 12v for so short a time. As you saw a 6v horn is very loud on 12v and with short periods of usage should last longer than you do.
Fox #1261683 04/06/2018 4:34 PM
Check the OUTPUT from the relay first thing 🎩
Then the wire between relay and horn 🎩
Also the ground connection at the horn 🎩
Tophat
1950 4400
1949 3100
1946 2 ton flatbed
1949 3800 panel
1952 3100 panel (newest one)
Queen Creek AZ
Fox #1261686 04/06/2018 5:10 PM
Sir Searchalot
Sir Searchalot
Does this mean you shorted the mast wire to ground?
Fox #1261758 04/07/2018 1:16 PM
Fox
Offline
Bartamos, yes I shorted the mast wire to ground. All the wires are new.
1970 Chevrolet C10
"Ole Red Girl"
More pictures here
Parts trucks-
Tiny #1261788 04/07/2018 5:45 PM
Sir Searchalot
Sir Searchalot
What horn do you have? The trumpet ooga style or other?
I agree with Tiny. It has been proven here many times. Metal vibration plate, big internal contacts and electromagnet wires can take 12V. Short bursts.
As Tophat says, check output of relay, but quickest way is to check horn positive terminal to see if 12V is getting there.
If 12V at horn and horn has good ground connection:
Take horn to bench or fender. Take off all horn wires and install direct hot from 12V battery and direct neg from battery. (no relay) Tap the neg for a second to test. Feel horn while testing. Any noise of vibration is a good sign. There is usually a adjustment screw/bolt to change the pitch. Try turning it. Could be that horn is just rusted or corroded. Could be contacts inside are "frozen" open or "frozen" closed. Check continuity between pos terminal and horn case. (power off). If horn has only one terminal (pos), be sure the ground test clip is on a shinny clean metal spot of horn/bracket. Be sure positive terminal insulator is still insulating.
I assume if there is a fuse, you have checked it. Assume a 12V relay.
You can test on the bench with a 12V battery charger as your power supply. Short bursts.
If all else fails, if you can't take it apart, before discarding, hold in one hand and tap all around on it with a soft blow hammer in the other hand. Increase impact after testing. Then throw it across the yard, and test. Then throw it away and yell "honk" out the truck window.
Fox #1261825 04/08/2018 12:41 AM
Fox
Offline
Thank ya sir. That should give me a great start. If it is indeed junk, I have a 12 volt horn off my Dad’s old green Ferd farm truck. I always loved the sound of that old horn.
1970 Chevrolet C10
"Ole Red Girl"
More pictures here
Parts trucks-
