0 members (),
149
Mod | | | Forums66 Topics128,113 Posts1,056,619 Members48,450 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2005 Posts: 1,624 Shop Shark | | Shop Shark Joined: May 2005 Posts: 1,624 | Here's a new twist...I need to remove the Bondo, not put it in. The PO shave the door handles and I want to reinstall them. He pulled the handles then body filled the holes. How can I remove the putty without banging the very good and straight sheetmeatal up or messing up the holes for the handle. The hole on the inside of the door will be somewhat hard to get to due to a large brace. Thanks
| | | | | Joined: Feb 2006 Posts: 395 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 395 | just redrill thru the filler,,if installer of the filler has dimpled the area and you install handles over the filler it will most likly crack out in use as it is not good to use filler in stress areas...doc | | | | | Joined: Nov 2004 Posts: 1,552 Shop Shark | | Shop Shark Joined: Nov 2004 Posts: 1,552 | beltfed:
Blasting is a great way to remove filler and maintain the integrity of the sheet metal below. Any good blasting with experience on body panels will know the process and the media to use for body filler removal.
Good luck with your project.
Tony | | | | | Joined: May 2007 Posts: 3 Junior Member | | Junior Member Joined: May 2007 Posts: 3 | If you heat bondo with a torch it easily scrapes off. I've done it many of times! | | | | | Joined: Oct 2005 Posts: 4,257 "Hey! I sound like Darth Vader!! | | "Hey! I sound like Darth Vader!! Joined: Oct 2005 Posts: 4,257 | | | | | | Joined: Apr 2001 Posts: 439 Shop Shark | | Shop Shark Joined: Apr 2001 Posts: 439 | Blasting bondo uses alot of sand (takes long).
Sand/drill/whatever it takes to get it out.
Shoot, you can carve out a little at a time with a knife if you wanted. | | | | | Joined: Apr 2005 Posts: 641 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 641 | yep propane torch and puddy knife | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | Take a 3M paint/rust stripper wheel on a drill to it. It will take the bondo off and do nothing to the metal. I have done this and it works really well. The wheel is sometimes referred to as a metal conditioning wheel. | | | | | Joined: May 2007 Posts: 275 Shop Shark | | Shop Shark Joined: May 2007 Posts: 275 | A propane torch and putty knife is a lot faster and easier. I have to do the samething tomorrow. Remove some old bondo the PO applied triing to fill some dents that he didn't bother pulling out.
Frkan
No better smell than that of fresh paint. I've been building and painting cars/trucks for 47 years. Not gonna stop now. http://www.coxcustomcars.com/ | | | | | Joined: Dec 2005 Posts: 92 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2005 Posts: 92 | Paint Striper and a plastic bag. keep it warm two coats will work And if tammy fay did it try more Maxx
52 GMC Grumman Olson Kurb Side stepvan T3-8(Comet)69 GMC 1/2-ton
