2 members (cmayna, Gray_Ghost), 168 guests, and 0 robots.
Topics128,114
Posts1,056,613
Members48,450
#126155 05/12/2007 12:52 PM
Here's a new twist...I need to remove the Bondo, not put it in. The PO shave the door handles and I want to reinstall them. He pulled the handles then body filled the holes. How can I remove the putty without banging the very good and straight sheetmeatal up or messing up the holes for the handle. The hole on the inside of the door will be somewhat hard to get to due to a large brace. Thanks
#126156 05/12/2007 1:57 PM
just redrill thru the filler,,if installer of the filler has dimpled the area and you install handles over the filler it will most likly crack out in use as it is not good to use filler in stress areas...doc
#126157 05/12/2007 6:05 PM
beltfed:
Blasting is a great way to remove filler and maintain the integrity of the sheet metal below. Any good blasting with experience on body panels will know the process and the media to use for body filler removal.
Good luck with your project.
Tony
#126158 05/12/2007 6:11 PM
Junior Member
Junior Member
If you heat bondo with a torch it easily scrapes off. I've done it many of times!
#126159 05/12/2007 7:23 PM
Stinks, though.
#126160 05/14/2007 4:05 AM
Blasting bondo uses alot of sand (takes long).
Sand/drill/whatever it takes to get it out.
Shoot, you can carve out a little at a time with a knife if you wanted.
#126161 05/14/2007 9:21 AM
yep propane torch and puddy knife
#126162 05/18/2007 11:59 AM
Take a 3M paint/rust stripper wheel on a drill to it. It will take the bondo off and do nothing to the metal. I have done this and it works really well. The wheel is sometimes referred to as a metal conditioning wheel.
1951 1 Ton Completed
#126163 05/19/2007 5:02 AM
A propane torch and putty knife is a lot faster and easier. I have to do the samething tomorrow. Remove some old bondo the PO applied triing to fill some dents that he didn't bother pulling out.
Frkan
No better smell than that of fresh paint. I've been building and painting cars/trucks for 47 years. Not gonna stop now.
http://www.coxcustomcars.com/
#126164 05/23/2007 9:46 AM
Paint Striper and a plastic bag.
keep it warm two coats will work
And if tammy fay did it try more
Maxx
52 GMC Grumman Olson Kurb Side stepvan T3-8(Comet)69 GMC 1/2-ton
