0 members (),
110
Mod | | | Forums66 Topics128,183 Posts1,057,264 Members48,467 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2010 Posts: 436 'Bolter | | 'Bolter Joined: Apr 2010 Posts: 436 | I have a 1962 C10 (X-Frame) and I need to replace the carrier bearing. The problem I am running into is that the 2 bolts are buried in the center of the X and are very difficult to get to. On my old '63 C10 (ladder frame), there was easy access to remove and replace the carrier bearing.
It looks like I will need to remove the front driveshaft and the emergency brake system from the X before I can access the carrier bearing bolts. Is this correct? Is there an easier way to do this that I'm missing?
Thanks in advance. | | | | | Joined: Nov 2000 Posts: 1,974 'Bolter | | 'Bolter Joined: Nov 2000 Posts: 1,974 | Maybe this link will help you find the info you need. https://www.stovebolt.com/techtips/chevy_manuals_60_66.htmI should remember how to do that as I replaced the carrier bearing in my 66 C10 with an X-frame...
Professional Novice
| | | | | Joined: Apr 2010 Posts: 436 'Bolter | | 'Bolter Joined: Apr 2010 Posts: 436 | Thanks! I have the Factory Assembly Manual, somewhere. I've moved since the last time I used it, and I can't seem to locate it.
