5 members (bajabob, Steelonsteel, klhansen, TUTS 59, ShopRag), 102 guests, and 3 robots.
Topics128,261
Posts1,058,327
Members48,485
#126124 05/11/2007 1:48 PM
Also while I'm finishing my second cup O’ coffeeeee this morning, and was an thinking bout spraying, I got to wondering where do the fumes go in a professional spray booth? Years ago when we sprayed the product that built with lacquer to comply with OSHA regulations all that was required was an approved metal spray booth with filters. The filters took out the solid particles but the fumes were simply exhausted out into the atmosphere.
I understand that some of the products used to day are friendlier to the environment but not necessarily to the lungs. When using the 2k systems the approved spray booths still remove the solids and vent the fumes out into the atmosphere, correct? So even though we have our fresh air suit on, if the air is being drawn from down wind of the spray booth taint we still getting a dose? And what about the passerby that is downwind? All of the professional booths that I have seen vent vertically, I suppose the thinking is that by the time it reaches back to the ground level it will have dissipated enough to not be a human hazard?
As stated in a previous discussion, I’m looking forward to the day when they get the water based paints perfected.
Denny Graham
Sandwich, IL
Denny G
Sandwich, IL
#126125 05/11/2007 1:51 PM
I dunno, all the booths I have seen had filters(but I can't see them trapping all the fumes), & Robin58 says his local DEQ wanted regular furnace filters. I guess they are more concerned w/particles over fumes.
My \'64\'s in the Gallery
Pictures in my Photobucket
1964 C10 Custom Cab 350/700R4
1964 Suburban 350/700R4
1979 Ford F350 4x4 400/c6
#126126 05/11/2007 2:15 PM
I think it is the solids that do the most damage. I am no expert, but the fumes are lighter than air and dissipate up into the atmosphere. It is the solids that clog lungs and contaminate the soils and water.
Never hold your farts in. They travel up your spine and into your brain...that is where crappy ideas come from.
#126127 05/11/2007 2:27 PM
what's required for booth exhaust depends on where you are - for starters most up to the minute systems now are downdraft, but vent straight up, and particulate filters have also gotten very high tech, but some areas do require very spendy scrubbers, water washing, or even carbon filters - I'd think CA would have the toughest standards
work out a way to 'biofilter' the exhaust and you've got it covered - pump the exhaust air into a mound of soil grin
