2 members (Patharr, 1 invisible),
45
Mod | | | Forums66 Topics128,090 Posts1,056,027 Members48,432 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2007 Posts: 44 Member | | Member Joined: Apr 2007 Posts: 44 | Working on 1950 frame, pressure cleanded scraped mud tried da sander with 150 grit and its taking the surface rust off, theres no pitting or serious rust on this truck, i sanded to the black, i read about sandblasting to bare metal, is this necessary? Is my da sanding and removing surface rust okay? whats the hardest grit i should use without damage? Then do i still need etching primer or can i use a rustoleum primer before painting the frame? Thanks for the help | | | | | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | You can't damage the frame with sandpaper. Its very thick.
It depends on what you are going for. If you are doing a show truck, then strip to bare metal and use etching primer or have it powdercoated. If you just want to use something like POR15 or Zerorust, then all you have to do is clean the rust off the surface and paint it on with a brush.
