2 members (Hotrod Lincoln, baldeagle), 83 guests, and 2 robots.
Topics128,037
Posts1,055,466
Members48,424
#1261054 03/31/2018 10:15 PM
I just want to confirm from what I’ve been able to research on here that a regular HB puller should work on removing a ‘53 235 harmonic balancer? A couple bolts I tried didn’t seem to snug up well and wanted to check here before I damage anything. I’m sure the threads are just full of years of crud.
Thanks in advance,
1953 Canadian GMC 9314 w/ (factory) Chevy 235
H Online: Content
Use a 3/8-16 tap to chase the threads. Also, be sure the jackscrew on the puller is small enough to pass through the hole in the balancer and actually bear against the front of the crankshaft snout. If the end of the jackscrew is bigger than 3/4" in diameter it will probably jam against the balancer hub without pushing on the crank.
Great, thank you!
Ex Hall Monitor
Ex Hall Monitor
A 1/2" drive 9/16" socket is the perfect size to fit through the center of the balancer for the puller to push against.
Thanks for the tips, it came off easily. Anyone have their preferred speedi sleeve? I see a few offered on Rockauto, but they’ve steered me wrong on a couple items recently.
Cheers,
H Online: Content
Since the hub diameter on all the Chevy sixes is the same as a small block V8, just go to your corner parts store and buy a sleeve for a 350. Mission accomplished!
Ahh, should be no issue then. Thanks,
Silly question, but what is the sleeve for? Are you running without an HB?
Michael P. O'Connor
H Online: Content
The speedy-sleeve is a thin band of stainless steel that is a press fit over the balancer snout. It covers the groove left by thousands of miles of the front seal rubbing on the balancer hub, the one that chews up a new seal and causes oil leaks. The other option is to buy a new balancer.
A "speedy sleeve" in this application works like a charm.
Rockauto.com
I have also had good service/luck with a "speedy sleeve" with the 3100 rear axle seals.
