0 members (), 106 guests, and 0 robots.
Topics128,101
Posts1,056,181
Members48,436
#1260758 03/30/2018 1:47 AM
I have a C60, 1961, engine is a 235 per block number (possibly a replacement for what should have been a 261).
The engine is straight piped with about 5 feet of pipe, seems like 1 1/2" pipe... kinda narrow pipe I would think but maybe fine.
Truck runs fine, but does backfire on downgrades with a load on (it's a dump truck).
Should this engine have a muffler, or can the carb be tuned for it to run okay with a straight pipe?
Engine has a single barrel carb.
Dan
Leo Offline
Moderator
Moderator
Not street legal without a muffler where I live...
Moderator
Moderator
2 Offline
Wish the LEO's would enforce the noise limit here in mid Mo.
On cars, trucks and Harley's.
I have to put my fingers in my ears sometimes when I'm outside.
They are that loud.
Don
"The Flag Pole"
1946 2-Ton grain truck
1946 3/4-ton pickup,
1953 1-ton pickup
1957 1-ton flatbed dually,
1954 Pontiac Straight Eight
sounds like you don't want to spend any $ on it.
ron
Sir Searchalot
Sir Searchalot
Yes you should have a muffler. The backfire may be something else. Summit has mufflers for $24. 1 1/2" inlet/outlet.
I guess I mis-communicated...
Some engines run better with back pressure, and some will run fine with straight pipes.
I guess I should have put this in the engine section... my bad. :o
Dan
Around my neighborhood running without a muffler can be hazardous to your health.
I ran without a muffler on my former '54 4100. Pipe straight out the back. Rather annoying after a while. I put a 24 inch glass pack on it and it became much more pleasant. Performance was the same if not slightly better with the muffler. drive
Sir Searchalot
Sir Searchalot
Yes 1200 HP drag motors and formula 1 motors run better. But we were not taking about them. We all recommend a muffler on yours. It will not run better without a muffler, It will sound like it runs better to you, but not to the cops or your neighbors. You will get a headache on an extended trip.
Constant loud sound is how they get secrets from the enemy. So be careful not to give up your pin number.
To be clear, you can run without a muffler if you want to. There just is no known advantage to a 235 stock motor. IF the backfire is cause by low "backpressure", tuning the carb will not help. (not sure what "tuning" you would do to a B1). You may mess up a good running truck however. Adding a muffler may not stop the backfire either.
Bartamos, thank you for that answer. I'll look into installing a muffler on the truck. It's got farm use tags on it so in Virginia, no inspection is needed, and the cops don't make an issue of it... but it is pretty darned loud to drive the thing. :o
thanks again, all
Dan
