5 members (Gdads51, 78buckshot, Opelika Tom, klhansen, 1 invisible), 122 guests, and 3 robots.
Topics128,062
Posts1,055,847
Members48,428
#1260472 03/28/2018 7:44 AM
Hello,
I have a 62 C-10 with a 235 6cyl and 3 on the tree. It’s 100 in the summer here. I want to install A/C. Do any of you know if the 235 does OK with A/C, and do you have any advice on the type/brand that works best? Thanks!
JPigg 62 C-10
I have a Vintage Aire in my '62 C10. I do have the 327 SBC though. I've been very happy with the unit. I installed it about 6 years ago and it was a clean install using the factory controls already installed in the dash.
I had to specify V8 when I ordered it. I know they make the mounts/brackets for the I6, you just have to specify what you need.
As for the power, I can't comment from experience, but have heard it is functional, but will take a bit of your power on the 235. I know others have done it. Maybe they can comment on their own experiences.
Thanks for the input!
JPigg 62 C-10
I hope you get more Replys I want to put AC on my 59 (235 ) also . GOTTA have more info .
Good Luck !
59 chevy apache fleetside
2007 dodge diesel
84 toyota 4 runner, v8,propane power
This may not be any help, but I saw a 55 Chevy Nomad with a 235 and air conditioning. This was some years ago at a cruise. The rotary compressor was mounted high on the engine above the generator. I think it had an under dash unit, so was probably dealer or aftermarket installed. Don't know about power consumption.
Professional Novice
Sir Searchalot
Sir Searchalot
It's pretty simple. You can install a donor vintage under dash unit or aftermarket kits. Al the components are the same. Compressor, clutch, evaporator, blower, condenser, accumulator. Buy the kit or buy the pieces. Sanden compressors are the most popular. It's all about budget and if you want to do all the work to assemble the parts, have the hoses made and have it evacuated and filled. It is a DIY friendly install. Not high tech.
Mount everything and hose it up.
As far as motor size. A/C will always take power away, but many vehicles with small motors have A/C. A 235 is not that small. It DOES have a tendency to cause overheating in a hot state like mine. Some folks have to upgrade to bigger radiator/better cooling system. Especially for stop and go driving.
I will agree with Bartamos about heat. My truck did run a lot hotter after I installed the A/C unit, but adding the factory fan shroud brought that right back under control. Runs nice and cool again.
Sir Searchalot
Sir Searchalot
Who is Bartimos?
Your alter-ego? secret
LOL!! Sorry, typo
