3 members (Hanks custodian, Gray_Ghost, 1 invisible), 85 guests, and 4 robots.
Topics128,056
Posts1,055,803
Page 2 of 2 1 2
Have you read the Stovebolt Tech Tip on 12 volt conversion?
Yes sir I did. Didn't say anything about headlight relays. Kinda why I'm asking.
Headlight relays have been in use since the 1940's so it's nothing new, and there's a very good reason to do so. Using them on 6V systems is particularly beneficial. Every time electric current passes through a switch or a connection, a tiny bit of voltage is consumed to push the electrons through the connection. It's called "voltage drop". That leaves slightly less voltage available to do the job once it gets to the headlights. Stack up 5 or 6 such connections from the battery, to the ammeter, to the light switch, to the dimmer switch, to a junction block, to the headlight filament, and then negotiate a similar ground path back to the battery. Auto makers are notorious for pinching pennies and using the smallest gauge wires they can get away with. It affects their bottom line when they're producing millions of vehicles a year, and their shareholders don't really care if you can actually see where you're going. You'll need to carry a flashlight to check if the headlight is actually burning.
Now- - - -run a HEAVY wire , like a #8 or so, from the battery cable at the starter to the radiator core support, and tie it into two relays, one for high beam and another for low, and run a heavy ground wire back to the engine, body, or frame (wherever the battery ground cable is attached). Use good, new wires (maybe #12 or so) from the relays to the headlight connectors, and back to the common ground. Use the signal from the dimmer switch just to trigger the high and low beam relays. You've just eliminated 80% or so of the connections the headlight current must negotiate and made the headlights noticeably brighter in the process. Is it worth it? Thousands of purchasers of aftermarket headlight relays have certainly thought so, for as long as I can remember!
Riding in the Passing Lane
With the headlights on, take jumper wire from the pos. bat. post to the hot wire on the headlight plug. You will be surprised how much brighter the lights get.
George
1972 Chevy c10 Cheyenne Super
Insomniac
Insomniac
If you want brighter headlights, forget about installing relays and install LEDs. Forget halogen; that's 1970's tech.
Gord 🇨🇦
1954 1/2 ton 235 4 speed
George
This test will let you know if you need the relays or not. I would add doing a similar test of the ground by jumping from a known good ground (battery would be best) and the ground of each headlight. A relay only addresses the positive side of the equation.
Carl
C Online: Content
Why upgrade to 12v? So you can keep your phone charged while you text and drive!! Ohhhhhhh, don't get me cookin' about that!
Craig
Actually, most personal electronics run on 5 volts, so the 7+ volts available when a 6V system has the engine running charges stuff just fine! Ditto on the texting and driving- - - - - -shove somebody's smart phone where the sun don't shine. but use a little K-Y jelly if you're feeling merciful!
I recently bought a cheap/Chinese (shipped from China), cigarette-lighter socket-adapter for two USB ports.
The adapter displays vehicle electrical system voltage. I will post a report on how well it works on a 6v system.
On my small 12v truck, it displays a little less than 12v when the truck is off, and it shows around 12.4v when the truck engine is running.
I’ll test it on a 6v truck (idling, and turned off) - charging a GPS and a cell phone (separately, and together).
Page 2 of 2 1 2
