2 members (Rich'sToys, Alex52), 123 guests, and 5 robots.
Topics128,186
Posts1,057,211
Members48,465
Hello. Im working on a 1964 K20 fleet side and was thinking of doing a very moderate modification on the rear wheel well openings. I think they sit too low for a 4x4 and want to open it up without making it look like a modification. Has anyone done this or have pics of doing this?
Thanks!
I've been wanting to do something similar. I want to put some wide 60 series tires and wheels on the rear. What I wanted to do is form metal wire around the wheel well and curl the flat sheet metal back around the wire to open the opening to give room for the beefier tires.
Tejas
One way of doing this could be to use larger wheel wells from a C60 or other similar sized truck. I did this on my truck. Ultimately did put bigger wheels on so will be changing them back to the original size wells. I can send you a picture if interested. I will be selling the wheel wells if too.
1964 K10 Fleetside Pickup Truck
Thanks man!
