1 members (Phak1),
48
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,073 Posts1,055,908 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2014 Posts: 94 Shop Shark | | Shop Shark Joined: Oct 2014 Posts: 94 | Distributor is '50 216 (the better one of my 2) Eng is '53 (full pressure) 235
Question is...is there suppose to be a gasket/O-ring on the distributor shaft going into the block? | | | | | Joined: Sep 2011 Posts: 1,453 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 1,453 |
BC 1960 Chevy C10 driver 261 T5 4.10 dana 44 power loc 1949 GMC 250 project in waiting 1960 C60 pasture art Retired GM dealer tech. 1980 - 2022 | | | | | Joined: Jan 2018 Posts: 189 'Bolter | | 'Bolter Joined: Jan 2018 Posts: 189 | I was wondering the same thing on my distributor. They must not have cared much about a little dirt in the engine, with open vents on the valve cover, etc. Is the distributor supposed to wiggle around a little while it's running? | | | | | Joined: Jan 2014 Posts: 3,683 'Bolter | | 'Bolter Joined: Jan 2014 Posts: 3,683 | Depends on your definition of “a little.”
Is your grease cup intact with the little spring and Bakelite button?
1951 3100
| | | | | Joined: Feb 2004 Posts: 29,777 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,777 | Is the distributor supposed to wiggle around a little while it's running? No, it's supposed to move a LOT while the engine is running. The vacuum advance moves the whole distributor housing, constantly, as manifold vacuum changes. Jerry
| | | | | Joined: Mar 2017 Posts: 326 'Bolter | | 'Bolter Joined: Mar 2017 Posts: 326 | My 56 had a lot of wiggle, so much that I was afraid that I had a bent shaft. But it went away as soon as I refilled and adjusted the grease cup. It does make a difference.
1956 Chevy 3200, 235 w/3 speed
| | | | | Joined: Jan 2018 Posts: 189 'Bolter | | 'Bolter Joined: Jan 2018 Posts: 189 | I have the grease cup which I refilled, but I don't recall seeing a spring, or any other pieces. Just a hole, and the screw on cap.
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | You have to dig/pull them out of the grease in the "stem" (the Distributor Shaft Fitting). | | |
