5 members (Oswald, 55shaker, Barney1951, Otto Skorzeny, WICruiser), 83 guests, and 0 robots.
Topics128,050
Posts1,055,646
#1259722 03/22/2018 5:14 PM
Distributor is '50 216 (the better one of my 2)
Eng is '53 (full pressure) 235
Question is...is there suppose to be a gasket/O-ring
on the distributor shaft going into the block?
No
BC
1960 C60 pasture art
I was wondering the same thing on my distributor. They must not have cared much about a little dirt in the engine, with open vents on the valve cover, etc. Is the distributor supposed to
wiggle around a little while it's running?
Depends on your definition of “a little.”
Is your grease cup intact with the little spring and Bakelite button?
1951 3100
No, it's supposed to move a LOT while the engine is running. The vacuum advance moves the whole distributor housing, constantly, as manifold vacuum changes.
' Offline
The grease cup & it's internal parts are essential .
They keep the distributor from any wiggle .
PIC of the grease cup
https://s26.postimg.org/kpn00de9l/Dist_Grease_Cup_Spring_Plug.jpg
George
'54 3600
1954 3600
Now cruising in
The Passing Lane
George,
Very nice photo of those parts.
Here is the photo without ads.
Did you make that photo?
In case the link to that photo goes bad, I have attached it, below.
If you do not mind, I'll post this somewhat unclear illustration from a Master Parts Catalog (for people reading this in the future).
http://chevy.oldcarmanualproject.com/parts/1929_54/154.htm
http://chevy.oldcarmanualproject.com/1929_57chevyparts/57cmpc0223.htm
My 56 had a lot of wiggle, so much that I was afraid that I had a bent shaft. But it went away as soon as I refilled and adjusted the grease cup. It does make a difference.
1956 Chevy 3200, 235 w/3 speed
I have the grease cup which I refilled, but I don't recall seeing a spring, or any other pieces. Just a hole, and the screw on cap.
You have to dig/pull them out of the grease in the "stem" (the Distributor Shaft Fitting).
