5 members (Jay R, Jon G, Joe H, TUTS 59, 68ironhead), 107 guests, and 2 robots.
Topics128,049
Posts1,055,747
#1259726 03/22/2018 6:39 PM
I have a SM420 in my 49-3100. Transmission runs and shifts fine however the shifter lever is wobbly and I would like to fix this.
I have new replacement parts if needed - shifter lever, fulcrum pins, spring, retension cup and retention cap.
Questions before I start. Is there a rubber or plastic washer or bushing that goes under the ball on the shift lever? The fulcrum pins are press fit. How is a good way to remove and install new ones?
Thanks for any advice or help.
dougs #1259749 03/22/2018 9:55 PM
No, Here is everything you will need to install the shifter into the top loader of the sm420.
https://www.ebay.com/itm/NP435-SM420-SM465-4-SPEED-TRANS-AX94906-SHIFT-STICK-HOLD-DOWN-REPAIR-KIT/122931100902?hash=item1c9f43bce6:g:wh4AAOSweARZdRqH&vxp=mtr
1953 Chevrolet 3100
In the DITY Gallery
Video of the 261 running
1964 GMC 1000
dougs #1259750 03/22/2018 10:19 PM
IIRC, I grinded off the heads of the fulcrum pins and they slid right out. Make sure to stuff a rag down in the shifter hole so they don't fall inside the trans. Look for some rolled steel pins of the appropriate size at your local hardware store. If needed you can drill out the fulcrum pin holes to accept a slightly larger pin. The rolled pins are also sold by Novaks. They are SM420 experts. thumbs_up
Be advised, nothing you can do will make the shifter feel as snug and tight as a new car shifter. There'll still be alot of play but it shouldn't flop and slop around quite as bad after your new parts are installed.
Matthew 6:33
1952 Chevy 1/2-ton 3100
Late '55 235/SM420/torque tube 3.55
Dalton Highway survivor (using original 216)
www.truckwithaheart.com
dougs #1259752 03/22/2018 10:46 PM
I wondered how floppy my 4-speed gear shifter was so I measured it.
Engine off and:
in neutral, the gear shift knob wobbles back and forth sideways 3 1/2".
in granny gear, 1".
in 4th gear, 1 1/2".
Mine doesn't seem excessive. It shifts just fine.
dougs #1259757 03/22/2018 11:11 PM
Sir Searchalot
Sir Searchalot
Fulcrum pins? Are you talking about the bayonet pins for the shift cup? If they lock the cup down and load the spring, they are OK as is.
The 420 has always had a "loose" feeling. Those parts will tighten up the "throw" distances. You can't change that.
But I don't know if wobbly means rattling while driving or long throw distances or ?
Remember: if it ain't broke don't fix it. You are going to screw something up that causes you to remove the trans if not careful.
dougs #1259759 03/22/2018 11:15 PM
dougs #1259783 03/23/2018 1:40 AM
My pins were extremely worn where the edges of the retainer had cut into them over the years, so I assumed OP's was the same. Replacing with new pins probably did more to tighten it up than new spring and cups.
Matthew 6:33
dougs #1259785 03/23/2018 1:47 AM
If a driver rested his/her hand on the shifter all the time, then the shift forks could be worn out making it sloppy...
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
dougs #1259789 03/23/2018 2:18 AM
Skooter
Were your pins original? How did you remove and install the new pins?
Thanks Doug
Skooter #1259796 03/23/2018 3:13 AM
Yes they were original.
Matthew 6:33
