0 members (),
102
Mod | | | Forums66 Topics128,186 Posts1,057,319 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2010 Posts: 436 'Bolter | | 'Bolter Joined: Apr 2010 Posts: 436 | What wheel seals are used on a 1962 C10 with a GM 55T rear end? I would like to change them while I have the axles out, but both O'Rielly's and NAPA show seals for HO35 and HO33 as the correct seals. I thought this was an HO52. | | | | | Joined: Nov 2005 Posts: 6,101 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,101 | Hy 62Stick, according to my old Victor seal book, the same rear wheel seal was used from 1946 - 62, Victor p/n 49225 which crosses to National 5801, hope that helps. | | | | | Joined: Apr 2010 Posts: 436 'Bolter | | 'Bolter Joined: Apr 2010 Posts: 436 | Thanks 3B, that's exactly the information I was looking for.
Once again, Stovebolt group knowledge to the rescue! | | | | | Joined: Jan 2016 Posts: 631 'Bolter | | 'Bolter Joined: Jan 2016 Posts: 631 | Rock auto shows two seals one for less than $3.00 and name brand for $62.00. Both appear to be the same size. | | | | | Joined: Apr 2010 Posts: 436 'Bolter | | 'Bolter Joined: Apr 2010 Posts: 436 | Thanks 3B! I was able to get the wheel seals using the National P/N you provided. That was the last piece I needed to complete my rebuild on the rear end.
It took trips to 5 different parts stores to get the wheel seals and I ended up getting 1 seal from the first and 1 from the fifth, buy I got it done. The Tank (my daughter's name for the truck) is back on the road. | | |
