5 members (Waveski, 49oneton, moparguy, HareCanvas, homer52), 78 guests, and 4 robots.
Topics128,184
Posts1,057,267
Members48,467
What wheel seals are used on a 1962 C10 with a GM 55T rear end? I would like to change them while I have the axles out, but both O'Rielly's and NAPA show seals for HO35 and HO33 as the correct seals. I thought this was an HO52.
3B Offline
Hy 62Stick, according to my old Victor seal book, the same rear wheel seal was used from 1946 - 62, Victor p/n 49225 which crosses to National 5801, hope that helps.
Thanks 3B, that's exactly the information I was looking for.
Once again, Stovebolt group knowledge to the rescue!
Rock auto shows two seals one for less than $3.00 and name brand for $62.00. Both appear to be the same size.
Thanks 3B! I was able to get the wheel seals using the National P/N you provided. That was the last piece I needed to complete my rebuild on the rear end.
It took trips to 5 different parts stores to get the wheel seals and I ended up getting 1 seal from the first and 1 from the fifth, buy I got it done. The Tank (my daughter's name for the truck) is back on the road.
