| | | Forums66 Topics128,211 Posts1,057,469 Members48,473 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2010 Posts: 202 'Bolter | | 'Bolter Joined: Oct 2010 Posts: 202 | I got hold of a 3:55 ring and pinion gear set for an AD series pickup off of eBay only to find out the shim set had not been included. Does anyone know where I can get a sim set?
Used shim would be acceptable.
Thanks Walt Williams
| | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Hello, WAlt,
This belongs in the Swap Meet?
There was no 3.54 R&P for A-D light trucks. Most likely, post that you want the shims/sims for the 3.55 R&P for the original torque-tube. | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | These folks have shims in many diameter combinations and thicknesses. http://ratechmfg.com/You might need to know the diameters your looking for. | | | | | Joined: Jan 2016 Posts: 631 'Bolter | | 'Bolter Joined: Jan 2016 Posts: 631 | PM me for set of NOS GM shims for torque tube. | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Could you accurately measure the ID, OD, and assorted thicknesses? With that info the next person might find a set from Raytech.
Otherwise offers to buy/sell should be done initially by PM or in the swap meet.
Thanks, Grigg | | | | | Joined: Oct 2010 Posts: 202 'Bolter | | 'Bolter Joined: Oct 2010 Posts: 202 | These folks have shims in many diameter combinations and thicknesses. http://ratechmfg.com/You might need to know the diameters your looking for. Thanks for the lead to Ratech. I have emailed them with measurements of the shims that came in the differential. Walt
