| | | Forums66 Topics128,087 Posts1,055,998 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2017 Posts: 82 Shop Shark | | Shop Shark Joined: Nov 2017 Posts: 82 | Hey fellas , I am going to be looking at a '52 panel truck tomorrow , wondered what you fellas could tell me about them? what are some things I should know about these ? are 216 's a babit engine? should babit be a deal breaker? I am planning to use it as a daily driver.. what about 235's? for give me if I am in the wrong forum ,I was not sure what one to post this under. is the only difference between a suburban and panel is suburban's have rear side windows?
| | | | | Joined: Apr 2005 Posts: 7,440 Bolter | | Bolter Joined: Apr 2005 Posts: 7,440 | Rust in every nook and cranny. If it truly is going to be your daily driver the mechanicals need to be 100%. Doors need to close properly. Engine should be freshly tuned. Did I mention rust? Good luck.ðŸ›
| | | | | Joined: Nov 2017 Posts: 82 Shop Shark | | Shop Shark Joined: Nov 2017 Posts: 82 | thank you , seller claims it is a "daily driver " in good condition ... I will hopefully see for myself tomorrow.
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | All 216 engines had a low-pressure oil system, with babbitted-bearing-surface rods. All pre-1954 235 truck engine would also have babbitt rod bearings. Both types of pre-1954 engines would have had 2-bolt valve covers. Here are locations of ID codes on low-pressure 216/235 engines. Post the codes here and we can help ID the engine. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | "Rust in every nook and cranny." is excellent advice from Martin.
Check lower rear cab corners. Check all around the edges of the interior floor panels and the interior side panels. | | | | | Joined: Dec 2015 Posts: 2,063 Big Bolt Forum Moderator | | Big Bolt Forum Moderator Joined: Dec 2015 Posts: 2,063 | at least on a panel, you don't have the side windows leaking water inside! Yes, look for rust all along the bottom of both sides as well as bottom of doors. Panel is not much different than a pickup for rust spots, just like a pickup with a super long cab!
Look at the floor in the rear, I believe it is plywood with hard rubber on top of it. (My 59 Suburban was). Look right in the back, center, inside the doors (assuming barn doors) and seeif it has been leaking there. If so, it should be addressed. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | "Look at the floor in the rear, I believe it is plywood with hard rubber on top of it. (My 59 Suburban was). " Rear floors were exposed wood in 47-55 panel & canopy trucks (a 1952 panel in this post had plywood - see below). http://www.1954advance-design.com/A-D_LCVA/LCVA-6-50.html" . . . the [1950] floor boards of panel and canopy express models were changed to plywood construction In the new construction a single panel of wood and five skid strips replaced thirteen floor boards and twelve skid strips. The new floor was positively sealed against dust leakage and the plywood made the floor 25 to 30% stronger than the former construction." 47-55st Suburban floor boards were high-density plywood with a ribbed linoleum "mat" glued to the one large piece of plywood. | | | | | Joined: Dec 2015 Posts: 2,063 Big Bolt Forum Moderator | | Big Bolt Forum Moderator Joined: Dec 2015 Posts: 2,063 | | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Mike,
You are right about Suburban rear side windows leaking water, and having rust under the window, inside the sidewalls, inside the the window frames, and on inner side wall.
As you posted, luckily, panels do not see those problems.
Rust/rot on the front floor boards, and rust/rot at the base of the rear doors - those can be problem areas? | | | | | Joined: Nov 2009 Posts: 639 'Bolter | | 'Bolter Joined: Nov 2009 Posts: 639 | Any time I look at one of these trucks I always look at the frame-rail near the front mount of the rear spring. I often find large rust holes.
Rear door hinges are often in bad shape on these.
I wouldn't be afraid of a 216 in a well cared for daily driver. I've used my '49 216 as an almost daily driver for about the first four years of ownership and as a daily driver and sole source of transportation for the last six years. Of course, a nice 235 would make a welcome improvement. | | | | | Joined: Jan 2000 Posts: 734 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 734 | If it truly is daily driver quality, I would expect the price to be on up there. Way up there.  Make sure you pull up the floormat and check for rust in the floorboard in front of the battery box as well as the drivers side floor around the parking brake (assuming it's the same layout as a pickup).
Matthew 6:33 1952 Chevy 1/2-ton 3100 Late '55 235/SM420/torque tube 3.55 Dalton Highway survivor (using original 216) www.truckwithaheart.com | | | | | Joined: Apr 2002 Posts: 2,168 A teacher, but always an apprentice. | | A teacher, but always an apprentice. Joined: Apr 2002 Posts: 2,168 | Also do NOT be afraid to walk away. Usually too good to be true is and many Bolters know how easy it is to drag home another "excellent condition" (that is junker/rusty/fixable/ I see potential) truck! We have all been there. Usepatience when buying, don't be over eager and let it "blind" you to the truth. Buy the best shape truck you can and you'll thank yourself down the road. | | |
